I am having problems when I’m trying to call a member function of an integer queue class from a global kernel. I get an error as following : “expression must have class type”. I basically can not use any member functions defined in CPU. Anyone knows how to handle this problem ?
Can you show a short, complete example that demonstrates the problem?
I don’t think it should be difficult to call a class member function in device code, but probably I’m not understanding the problem.
Here’s a simple example:
$ cat t549.cu
#include <stdio.h>
class A{
int data;
public:
A() { data = 0;}
__host__ __device__
void increment() { data++;}
__host__ __device__
void print_data() { printf("data = %d\n", data);}
__global__ void test(A a){
a.increment();
a.print_data();
int main(){
A h_a;
h_a.increment();
h_a.print_data();
test<<<1,1>>>(h_a);
cudaDeviceSynchronize();
$ nvcc -arch=sm_20 -o t549 t549.cu
$ cuda-memcheck ./t549
========= CUDA-MEMCHECK
data = 1
data = 2
========= ERROR SUMMARY: 0 errors
