since over the past days I was eagerly waiting for M2.7 REAPS to come out with quants suitable for single DGX Sparks but I could not find anything and also had holidays from monday to wednesday I created one myself. Unfortunately I only have a single spark plus a 256GB Threadripper with 2x 3090s so my setup is very shitty for calibrating with huge samples sizes and samples lengths.
Also running evals takes forever, I ran GPQA Diamond for over 15 hours just to discover I was too stingy with the max tokens at 16k and 30% of samples didnt finish reasoning within this budget. It still got 60% so the general intelligence seems to be there. Will run some more evals on external compute over the weekend. will need to rent some H200 most likely.
Anyways I thought i still share it here if someone wants to give it a go as well :)
Speed is basically the same as 122B A10B Qwen model with autoround.
There is definitely room for improvements with new kv cache quants landing in vllm. On a single spark with fp8 you can get around 100k context i guess. I havnt pushed it all too far since my agents are also sharing some portion of the ran most of the time
depth
prefill tok/s
decode tok/s
TTFT (ms)
0
2469.3 ± 13.3
29.28 ± 0.05
864.5
4096
2089.9 ± 12.5
27.73 ± 0.05
2784.8
8192
1890.3 ± 5.2
26.28 ± 0.05
5062.3
16384
1601.1 ± 6.5
23.88 ± 0.05
10647.7
Happy for any feedback, this is just a first draft. WIll need to pick some better and bigger datasets for REAP and quantisation calibration. Just wanted to validate everything end to end first before renting out more compute
The main repo now has some TQ options for KV cache, but this requires the whole model too.
You need turboquant-vllm for that one - for now.
It might be worth looking into setting that up for testing. This isn’t the only model that could fit on 1 Spark much more efficiently under such a framework.
Minimax is decent, but it has never been able to surpass the step-3.5-flash model. I’ve used many recently released models with ik_llama.cpp and lvllm (a variant of vllm), and they are all far inferior to step-3.5-flash, which is strange. Perhaps it’s because I’m using roo code.
does step-3.5-flash fit in one spark via vLLM? I think that is kind of the benefit of this specific reap model, it fits on one spark with enough headroom for 100k context (or even 110k if you are careful).
Has anyone been able to try this model on dual spark configuration? I am curious if that configuration would create more output t/s or just allow a greater context size.
