Has anyone successfully run Qwen2.5-27B on a DGX Spark and achieved decent inference speed?
I’m currently getting only about 4 tokens per second with both llama.cpp (BF16) and vLLM, and I’m looking for ways to improve performance.
My current setup:
Hardware: DGX Spark
Model: Qwen2.5-27B
Tried: llama.cpp (BF16 quantization) and vLLM
Current speed: ~4 tokens/second
Questions:
Is this expected performance for this model on this hardware?
What optimizations could I try to increase the token generation speed?
Are there specific configuration settings (batch size, tensor parallelism, quantization methods) that work well for this combination?
Any insights or recommendations would be greatly appreciated!
Below is my current setting ( recipe using spark-vllm-docker)
description: vLLM serving Qwen3.5-27B on DGX Spark 128GB
model: Qwen/Qwen3.5-27B
container: vllm-node
defaults:
port: 8000
host: 0.0.0.0
tensor_parallel: 1
gpu_memory_utilization: 0.81
max_model_len: 262144
env: {}
command: |
vllm serve Qwen/Qwen3.5-27B
–enable-auto-tool-choice
–tool-call-parser glm45
–reasoning-parser glm45
–language-model-only
–kv-cache-dtype fp8
–gpu-memory-utilization {gpu_memory_utilization}
–host {host}
–port {port}
–tensor-parallel-size {tensor_parallel}
–load-format fastsafetensors
–enable-prefix-caching
–attention-backend flashinfer
–max-num-seqs 32
–max-model-len {max_model_len}
–max-num-batched-tokens 32768
–trust-remote-code
recipe_version: ‘1’
cluster_only: false
solo_only: true
