mlx4_core: communication channel command 0x5 (op=0x24) timed out
One of our Linux servers, running SUSE x86_64 Linux got the following error, and the network interfaces went down.
Looking for any guidance on what this could be and how to address it:
ct 10 21:36:32 mtb0120qpr5 kernel: [4238431.515819] mlx4_core 0000:00:14.0: communication channel command 0x5 (op=0x24) timed out
Oct 10 21:36:32 mtb0120qpr5 kernel: [4238431.515825] mlx4_core 0000:00:14.0: device is going to be reset
Oct 10 21:36:32 mtb0120qpr5 kernel: [4238431.515829] mlx4_core 0000:00:14.0: VF is sending reset request to Firmware
Oct 10 21:36:32 mtb0120qpr5 kernel: [4238431.516494] mlx4_core 0000:00:14.0: VF Reset succeed
Oct 10 21:36:32 mtb0120qpr5 kernel: [4238431.516495] mlx4_core 0000:00:14.0: device was reset successfully
Oct 10 21:36:32 mtb0120qpr5 kernel: [4238431.516496] <mlx4_ib> mlx4_ib_handle_catas_error: mlx4_ib_handle_catas_error was started
Oct 10 21:36:32 mtb0120qpr5 kernel: [4238431.516507] <mlx4_ib> mlx4_ib_handle_catas_error: mlx4_ib_handle_catas_error ended
Oct 10 21:36:32 mtb0120qpr5 kernel: [4238431.516508] mlx4_en 0000:00:14.0: Internal error detected, restarting device
Oct 10 21:36:32 mtb0120qpr5 kernel: [4238431.516512] infiniband mlx4_0: ib_query_pkey failed (-5) for index 18
Oct 10 21:36:32 mtb0120qpr5 kernel: [4238431.516516] infiniband mlx4_0: ib_query_port failed (-5)
Oct 10 21:36:32 mtb0120qpr5 kernel: [4238431.795281] ib1: post_send_rss failed, error -5
The following is the lspci for the IB card:
00:14.0 0280: 15b3:1004
Subsystem: 15b3:61b0
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 25
Region 2: Memory at fa000000 (64-bit, prefetchable) [size=8M]
Capabilities: [60] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE- FLReset+
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x8, ASPM unknown, Latency L0 <64ns, L1 <1us
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed unknown, Width x0, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [9c] MSI-X: Enable+ Count=4 Masked-
Vector table: BAR=2 offset=00002000
PBA: BAR=2 offset=00003000
Capabilities: [40] Power Management version 0
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Kernel driver in use: mlx4_core
Kernel modules: mlx4_core
The following is a few of the Mellanox RPMs we have installed:
mlnx-ofa_kernel-4.7-OFED.4.7.3.2.9.1.g457f064.sles11sp4
mlnx-ofa_kernel-devel-4.7-OFED.4.7.3.2.9.1.g457f064.sles11sp4
mlnx-ofa_kernel-modules-4.7-OFED.4.7.3.2.9.1.g457f064.kver.3.0.101_107_default
Hello Greg,
Thank you for posting your inquiry on the NVIDIA Networking Community.
Based on the opcode, we researched internally and found that this issue was resolved a long time ago in f/w and driver update.
Please update the f/w and driver to the latest version available, for ConnectX-3 adapters this is MLNX_OFED 4LTS 4.9 and f/w depending on the PSID of the adapter, version 2.4x.xxxx.
If you still experiencing this issue after updating the driver and f/w, please do not hesitate to open a NVIDIA Networking Support Ticket by sending and email to networking-support@nvidia.com
We will gladly assist you through the support ticket.
Thank you and regards,
~NVIDIA Networking Technical Support
