Getting this error when trying to get a Connect EN card working on RHEL 6.3 64 bit. Have install the 2.4 drivers
[root@XXXX ~]# cat /var/log/dmesg | grep ml
Compat-mlnx-ofed backport release: 6a710e6
Backport based on mlnx_ofed/mlnx-ofed-2.x-kernel.git 6a710e6
compat.git: mlnx_ofed/mlnx-ofed-2.x-kernel.git
mlx4_core: Mellanox ConnectX core driver v2.4-1.0.0.1 (Mar 10 2015)
mlx4_core: Initializing 0000:04:00.0
mlx4_core 0000:04:00.0: PCI INT A → GSI 38 (level, low) → IRQ 38
mlx4_core 0000:04:00.0: setting latency timer to 64
mlx4_core 0000:04:00.0: vpd r/w failed. This is likely a firmware bug on this device. Contact the card vendor for a firmware update.
mlx4_core 0000:04:00.0: command QUERY_FW (0x4) timed out (go bit not cleared)
mlx4_core 0000:04:00.0: mlx4_enter_error_state: device is going to be reset
mlx4_core 0000:04:00.0: mlx4_enter_error_state: device was reset successfully
mlx4_core 0000:04:00.0: mlx4_enter_error_state: end
mlx4_core 0000:04:00.0: QUERY_FW command failed, err=-5, aborting.
mlx4_core 0000:04:00.0: Failed to init fw, aborting.
mlx4_core 0000:04:00.0: PCI INT A disabled
mlx4_core: probe of 0000:04:00.0 failed with error -5
Here is the firmware information about the card:
more /tmp/install-mlx4_en.log.3695_fw_update.log
CMD: /tmp/sfxter_ZuuLy6/mlxfwmanager_sriov_dis_x86_64/mlxfwmanager_pci -u --log-
on-update --ssl-certificate /tmp/sfxter_ZuuLy6/mlxfwmanager_sriov_dis_x86_64/ca-
bundle.crt --current-dir /tmp/10g/mlnx-en-2.4-1.0.0.1/ -L /tmp/install-mlx4_en.
log.3695_fw_update.log -y
Querying Mellanox devices firmware …
Device #1:
Device Type: ConnectX2
Part Number: MNPA19_A1-A2
Description: ConnectX-2 Lx EN network interface card; single-port SFP+; P
CIe2.0 5.0GT/s; mem-free; RoHS R6
PSID: MT_0F60110010
PCI Device Name: 0000:04:00.0
Port1 MAC: 0002c94ee93c
Port2 MAC: 0002c94ee93d
Versions: Current Available
FW 2.9.1000 2.9.1000
PXE 3.3.0400 N/A
Status: Up to date
When I run lspci I get the information below:
04:00.0 Ethernet controller: Mellanox Technologies MT26448 [ConnectX EN 10GigE, PCIe 2.0 5GT/s] (rev b0)
Any help you can provide would be appreciated.
