On CentOS 7.5 + Mellanox ConnectX-4 LX having troubs to configure interface.
I have Mellanox ConnectX-4 LX ethernet adapter:
~]# lspci | grep -i Mella
10003:01:00.0 Ethernet controller: Mellanox Technologies MT27710 Family [ConnectX-4 Lx]
10003:01:00.1 Ethernet controller: Mellanox Technologies MT27710 Family [ConnectX-4 Lx]
But when mlx5_core module loads there is an error:
mlx5_core 10003:01:00.0: PCI INT A: no GSI
mlx5_core 10003:01:00.0: Missing registers BAR, aborting
mlx5_core 10003:01:00.0: error requesting BARs, aborting
mlx5_core 10003:01:00.0: mlx5_pci_init failed with error code -19
mlx5_core 10003:01:00.1: PCI INT B: no GSI
mlx5_core 10003:01:00.1: Missing registers BAR, aborting
mlx5_core 10003:01:00.1: error requesting BARs, aborting
mlx5_core 10003:01:00.1: mlx5_pci_init failed with error code -19
Always receiving error while trying to read device configuration or open device - it tries to open wrong device (0003:01:00.0 and 0003:01:00.1 instead of 10003:01:00.0 and 10003:01:00.1):
~]# mstflint -d 10003:01:00.0 q
-E- Cannot open Device: 10003:01:00.0. No such file or directory. MFE_CR_ERROR
~]# mst status
MST modules:
MST PCI module loaded
MST PCI configuration module loaded
MST devices:
/dev/mst/mt4117_pciconf0 - PCI configuration cycles access.
domain:bus:dev.fn=10003:01:00.0 addr.reg=88 data.reg=92
Failed to open (/sys/bus/pci/devices/0003:01:00.1/config) for reading: No such file or directory
Failed to open (/sys/bus/pci/devices/0003:01:00.0/config) for reading: No such file or directory
Chip revision is: 00
/dev/mst/mt4117_pci_cr0 - PCI direct access.
domain:bus:dev.fn=10003:01:00.0 bar=0x00000000 size=0x0
mopen: Invalid argument
Chip revision is:
~]# flint -d /dev/mst/mt4117_pciconf0 query
Image type: FS3
FW Version: 14.21.1000
FW Release Date: 29.10.2017
Product Version: rel-14_21_1000
Rom Info: type=UEFI version=14.14.22 cpu=AMD64
type=PXE version=3.5.305 cpu=AMD64
Description: UID GuidsNumber
Base GUID: ac1f6b15d92d2f68 4
Base MAC: ac1f6b2d2f68 4
Image VSD: N/A
Device VSD: N/A
PSID: SM_2001000001034
Security Attributes: N/A
Paths /sys/bus/pci/devices/10003:01:00.1/config and /sys/bus/pci/devices/0003:01:00.0/config exist, but mellanox tools try to open wrong one. This error appears everywhere - query device/update firmware/reset device - tools just cut first digit of pci domain number.
The same stuff on Debian works great, but pci device was in 0000 domain (0000:86:00.0 and 0000:86:00.1). This error repeats on RHEL7 too - the same situation.
Looks like problem with 5-digit pci domain. Maybe someone faced and solved the similar problem?
