I am having issues getting a Mellanox ConnectX-5 card to connect via ethernet to the network. I am running RHEL 9.0 and have tried reflashing the firmware, configuring the card to use ethernet, and manually installing the OFED drivers.
Output of ifconfig. The IP is what it should be, but I can’t ping that address and I can’t ping anything from that address
enp65s0f0np0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.1.21.53 netmask 255.255.255.0 broadcast 172.1.21.255
inet6 fe80::e42:a1ff:feac:356 prefixlen 64 scopeid 0x20<link>
ether 0c:42:a1:ac:03:56 txqueuelen 1000 (Ethernet)
RX packets 12696 bytes 1667716 (1.5 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 18 bytes 1246 (1.2 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
I am getting the following message at boot from the mlx5_core driver:
modprobe -v mlx5_core
insmod /lib/modules/5.14.0-70.13.1.el9_0.x86_64/kernel/drivers/pci/controller/pci-hyperv-intf.ko.xz
insmod /lib/modules/5.14.0-70.13.1.el9_0.x86_64/kernel/net/tls/tls.ko.xz
insmod /lib/modules/5.14.0-70.13.1.el9_0.x86_64/extra/mlnx-ofa_kernel/drivers/net/ethernet/mellanox/mlxfw/mlxfw.ko
insmod /lib/modules/5.14.0-70.13.1.el9_0.x86_64/kernel/net/psample/psample.ko.xz
insmod /lib/modules/5.14.0-70.13.1.el9_0.x86_64/extra/mlnx-ofa_kernel/net/mlxdevm/mlxdevm.ko
insmod /lib/modules/5.14.0-70.13.1.el9_0.x86_64/extra/mlnx-ofa_kernel/drivers/net/ethernet/mellanox/mlx5/core/mlx5_core.ko
[ 2426.722748] mlx5_core 0000:41:00.0: mlx5_cmd_out_err:797:(pid 9277): ACCESS_REG(0x805) op_mod(0x0) failed, status bad operation(0x2), syndrome (0xabbc09), error(-22)
[ 2426.723820] mlx5_core 0000:41:00.0 (unnamed net_device) (uninitialized): mlx5e_ets_init, Failed to init ETS: -22
[ 2426.975062] mlx5_core 0000:41:00.1: mlx5_cmd_out_err:797:(pid 9277): ACCESS_REG(0x805) op_mod(0x0) failed, status bad operation(0x2), syndrome (0xabbc09), error(-22)
[ 2426.976277] mlx5_core 0000:41:00.0 (unnamed net_device) (uninitialized): mlx5e_ets_init, Failed to init ETS: -22
Any help would be appreciated
