Model not working after upgrading to Deepstream 7.1
• Hardware Platform (Jetson / GPU) Jetson Orin AGX
• DeepStream Version 7.1
• JetPack Version (valid for Jetson only) 6.2
• TensorRT Version 10.3.0
I was running a person detect YOLOv8 model as PGIE and person attribute model as SGIE in deepstream 7.0, jetpack 6.0 and tensorRT 8.6. Now I have upgraded it as per configuration mentioned above. I have build the new engine files for both models using deepstream7.1. I found that YOLOV8 model is working properly, however the person attribute model is not able to recognize any attribute.
To debug I print confidence in custom parser and found that all the values are less than 0.2 while earlier with 7.0 I was getting values higher then 0.55.
If needed I can provide you both the engine file created with 7.0 and 7.1. Below is the configuration I am using.
[property]
gpu-id=0
onnx-file=solider_model.onnx
model-engine-file=solider_model.onnx_b1_gpu0_fp32.engine
batch-size=1
net-scale-factor=0.00392156862745098
offsets=123.675;116.28;103.53
model-color-format=0
network-mode=0
process-mode=2
network-type=1
labelfile-path=labels.txt
interval=0
infer-dims=3;256;192
maintain-aspect-ratio=1
symmetric-padding=0
custom-lib-path=parser/libnvdsinfer_custom_impl.so
parse-classifier-func-name=NvDsInferParseSolider
classifier-threshold=0.55
I have checked the onnx model and it was created with opset 11. I have gone through the tensorRT 10.3 release notes and found that it is recommending to use opset 18 or 19. So I have created the model again, still the confidence score is too low. The onnx model created today or the previous one are still giving accurate result.
I am not using container. While converting to fp32 engine by deepstream there were no errors. I tried fp16 as well but the problem didn’t resolve. Please help.
Please refer to the sample deepstream_tools/yolo_deepstream at main · NVIDIA-AI-IOT/deepstream_tools for how to handle the Yolo model.
My question is for person atrribute model Solider used as SGIE and not for Yolo model. Please resolve.
The only change is TensorRT version upgrading. For the ONNX model TensorRT accuracy issue, please consult in TensorRT forum. Latest Deep Learning (Training & Inference)/TensorRT topics - NVIDIA Developer Forums
