• Hardware Platform (Jetson / GPU): dPU A40.
• DeepStream Version: 6.4-triton-multiarch.
• TensorRT Version: 8.6.2.3.
• NVIDIA GPU Driver Version (valid for GPU only): 525.147.05.
• Issue Type( questions, new requirements, bugs): questions.
I am using DeepStream with Python, specifically the repository GitHub - marcoslucianops/DeepStream-Yolo: NVIDIA DeepStream SDK 6.3 / 6.2 / 6.1.1 / 6.1 / 6.0.1 / 6.0 / 5.1 implementation for YOLO models to convert a YOLOv8x.pt model to ONNX for use in a single-class person detection pgie model. I’ve noticed significant differences in the results when comparing the model’s performance using Ultralytics for inference versus using DeepStream. In Ultralytics, I set the iou to 0.7 and the threshold to 0.5, and similarly in DeepStream, I set the nms-iou-threshold to 0.7 and the pre-cluster-threshold to 0.5. Am I configuring something incorrectly? Can you identify why there might be such a significant discrepancy in the results between the two methods?
Below are the results of using ultralytics for inference:
And here is the result from deepstream:
Here is the ultralytics code I am using for inference, config pgie deepstream, model pt and model onnx:
yolov8 - Google Drive
