Yolov3 deepstream vs pytorch pipeline differences
I have some question about running yolov3 in deepstream 6.0.1.
I have used yolov3 from darknet: YOLO: Real-Time Object Detection , trained it on custom dataset (GitHub - ultralytics/yolov3: YOLOv3 in PyTorch > ONNX > CoreML > TFLite) and deployed.
Everything works. Almost ^^
When I was training the model I have tested the model with some batch of pictures.
I got +/- 98% mAP on the dataset.
I have used the same dataset in my deepstream pipeline and I see some differences.
Some bboxes are just a little moved, some are not drawn at all.
I was trying to change some yolov3_config values (net-scale-factor, nms-iou-threshold etc) what is passed to nvinfer (config-file-path) but still the final mAP is much worse.
And maybe it’s important:
For instance for some picture, where I have 3 objects, confidence for all of them is above 60% (pytorch pipeline)
However, when I use deepstream pipeline (so the model is converted via trt) - the confidence is much lower (like 20-30%).
So maybe do you know what could be wrong here?
Of course I can append some of config files etc.
Thank you for help
Yes, please append your config file.
Besides please provide complete information as applicable to your setup, thanks.
• DeepStream Version
• TensorRT Version
• The pipeline being used
• Hardware Platform (Jetson / GPU): GPU A2000
• DeepStream Version 6.0.1
• TensorRT Version 8.0.1-1+cuda11.3
• NVIDIA GPU Driver Version (valid for GPU only) 470.86
• The pipeline being used:
yolo configs:
yolov3-1cls.cfg (8.1 KB)
yolov3_config.txt (895 Bytes)
Hi @BonTo , Could you try to use yolov3 model in our demo to test the mAP? About how to get the model, you can refer the link below. Thanks
https://github.com/NVIDIA-AI-IOT/deepstream_tao_apps
