modifiable lvalue error typedef to define 2D array
Im a newbie to Cuda and I am trying to use typedef to define a 2D array to make it easier to interpret the data. I have written a basic cuda program to test this out. I want to pass a 2D array from matlab and then pass a copy of that 2D array back.
typedef double twoDarray[9][2];
global void copyArray(const double *scat,
double *out1)
twoDarray *scat2D;
scat2D = (twoDarray *)scat;
twoDarray *out;
out = (twoDarray *)out1;
for (int i = 0; i < 9; i++)
for (int j = 0; j < 2; j++)
out[i][j] = scat2D[i][j]; // error: expression must be a modifiable lvalue
Can someone please tell me what i’m doing wrong? Is it that i’m trying to access a const array. This doesn’t make sense to me.
And how are you suppose to add code properly?
I’m not so sure what you are trying to do here, but there is at least a problem in the line you pointed:
Your “twoDarray” is “similar” (ie naturally castable) to a double**, right? Then “out” which is a “twoDarray*” is similar to a double***.
So “out[i][j]” is similar to a double*, and something tells me that this is not what you want to get. But ultimately, I just don’t get what you want to do…
for this i’m just trying to write a function that will take an 2D array and pass a copy of that 2D array back. I am trying to figure out how to use the typedef properly to make it easier to access mutliple-D arrays in CUDA. It should be noted that i’m calling this function from Matlab using the feval.
Your “twoDarray” is “similar” (ie naturally castable) to a double**, right? This is correct.
I want to be able to cast both CUDA input arrays as 2D arrays so i can easily interpret the correct indecies.
in matlab, i’ll have an array defined, scats (9x2). Then call Cuda and have it give me a copy of this array, out (9x2).
I’m by no mean a matlab (never used it) but for what I heard and according to this matlab stores multi dimensional arrays contiguously in memory and in a column-major order. So doing this kind of copy can simply be done by passing a reference to the first element of the array, and by copying the whole multi dimensional array as if it was a 1D one of size the multiple of the individual dimensions.
For example, your (9,2) 2D array in internally stored as a 18 long 1D array, starting form element (1,1) (very much like in Fortran actually).
Now, I (along with wikipedia) might be wrong, but this is at least worth trying.
Hello!
I have a similar situation, but I pass arrays to GPU from Python, not Matlab.
The code below compiles and works. It is absolutely meaningless, but it shows the principle.
The float aa[140] array is treated as 3D array float matr[5][7][4].
global void init_pcur(Cmcmcfit *mc) {
#define L 5
#define M 7
#define N 4
//int L=5, M=7, N=4;
typedef float mat_t[M][N];
int i, j, k;
/* Make arrays aa[140] and matr[5][7][4] overlay */
float aa[140];
mat_t *matr = (mat_t *) aa;
for (i=0; i < N; ++i)
for (j=0; j < N; ++j)
for (k=0; k < M; ++k)
matr[i][j][k] = ijk;
However, for my purposes this is useless: I need to overlay arrays with the dimensions dependent on blockDim.x, gridDim.x, threadIdx.x, and blockIdx.x. The nvcc compiler does not let it. The error message is
error: this operator is not allowed in an integral constant expression
If I try to use just variables int L=5, M=7, N=4, then the message is
error: expression must have a constant value
By the way, my gcc 4.4.3 allows expressions like typedef float mat_t[M][N], where N and N are variables. This is EXTREMELY useful in some cases. The code below compiles and works in Linux (you are encouraged to try):
#include <assert.h>
#include <stdio.h>
//#define N 9
void compare(int *array, int N, int M)
typedef int mat_t[N][M];
int i, j, k;
mat_t *matrix = (mat_t )array; / 3D array [any][N][M] /
assert( &matrix[i][j][k] == &array[(i
N+j)M+k] );
assert( matrix[i][j][k] == array[(i
N+j)*M+k]);
printf(“matrix[%d][%d][%d]=%d\n”, i, j, k, matrix[i][j][k]);
int main(void)
int i, N=9, M=5;
int foo[NNM];
for (i=0; i < NNM; ++i) foo[i] = (7*i+11)*3+8;
compare(foo, N, M);
return 0;
Does anybody know if it is in principle possible in CUDF C ?
Does NVIDIA plan to upgrade nvcc to include variable bounds in typedef float mat_t[M][N]?
