mmcly
November 15, 2022, 10:52am
1
hi nv team,
I enable the serial@3140000 (which is ttyTHS4 in system) in the devicetree.
accroding to the below link
I want to resize the buffer size (xmit_fifo_size) in userspace . but it return failed
I also try to change from the debugfs as follow but it show Permission denied
so how can I modify the uart buffer size ?
hello mmcly,
please try modify below via kernel sources.
$public_sources/kernel_src/kernel/kernel-4.9/drivers/staging/fwserial/fwserial.h
/* tuning parameters */
#define FWTTY_PORT_TXFIFO_LEN 4096
mmcly
November 16, 2022, 7:24am
4
thx @JerryChang
for me, What I want to change is the size of rx fifo. Another detail is the xmit_fifo_size I read from the system is 36, which is different from the param FWTTY_PORT_TXFIFO_LEN
hello mmcly,
could you please try revise the definition as following,
$public_sources/kernel_src/kernel/kernel-5.10/drivers/tty/serial/serial-tegra.c
#define TEGRA_UART_FIFO_SIZE 36
please recompile kernel sources and updating the kernel image for confirmation.
thanks
system
Closed
December 7, 2022, 1:56am
7
