• Hardware Platform (Jetson / GPU) AGX Xavier
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 8
Continuing the discussion from About deepstream sdk with yolov5: I am looking to run a custom trained yolov5 model in Deepstream. I modified the nvdsparsebbox_Yolo.cpp file to change the number of classes, but when I ran the code, I saw an assert at Line 139 - “assert(boxes.inferDims.numDims == 3);”. While I am expecting that the code needs to be modified, I am not sure how the outputs are structured in Yolov5. Can any of you give me some insight to how the structure of Yolov5 is different from that of Yolov4?
Thank you!
