more time taken by CUDA rather than reducing time
Hello All,
I am Deepak and I am very new to CUDA. I started with the first program given in book CUDA BY EXAMPLE and i was shocked to see starnge results when i tried to measure the time of execution.
If I run the program using g++ compliler, it takes around 20ms to run the program but if I use CUDA, its takes 90 ms to run the program.
Following is my code in both versions.
include <stdio.h>
#include <time.h>
#include <math.h>
#include <stdlib.h>
#define N   10
void add( float *a, float *b, float *c ) {
    int tid = 0;
    while (tid < N) {
        c[tid] = (a[tid]/(a[tid]*a[tid])) + (b[tid]/(b[tid]*b[tid]));
        tid += 1;
int main( void ) {
	float elapsed;
        float a[N], b[N], c[N];
        int i;
	clock_t timerStart, timerStop;
	for (i=0; i<N; i++) {
        	a[i] = (float) (i)/(i+1);
       		b[i] = (float) (i)/(i+1);
        	c[i] = 0;
    	timerStart = clock();
    	add( a, b, c );
	timerStop = clock();
	elapsed = (float) ( timerStop - timerStart ) / CLOCKS_PER_SEC;
	printf( "Time elapsed:  %f ", elapsed);
	for (i=0; i<N;i++)
	printf(" %f \n",c[i]);
	return 0;
MY CUDA VERSION is
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <cuda.h>
#include "cutil.h"
#include <time.h>
#define TIMECUDA
//#define TIMECPU
#define N 10
__global__ void add( float *a, float *b, float *c ) {
    int tid = blockIdx.x;   // TID is the block ID
    if (tid < N) {
int main( void ) {
	float *temp_a,*temp_b,*temp_c;
    	long i;
#ifdef TIMECUDA
	float elapsed_time_cpu_gpu,elapsed_time_add,elapsed_time_gpu_cpu;
#else
#endif
#ifdef TIMECPU
	float elapsed_time;
#else
#endif
#ifdef TIMECPU
#else
#endif
#ifdef TIMECUDA
	cudaEvent_t start,stop,startadd,stopadd,startback,stopback;
	cudaEventCreate(&start);
	cudaEventCreate(&stop);
	cudaEventCreate(&startadd);
	cudaEventCreate(&stopadd);
	cudaEventCreate(&startback);
	cudaEventCreate(&stopback);
#else
#endif
	cudaMalloc((void**)&temp_a,N*sizeof(int));
	cudaMalloc((void**)&temp_b,N*sizeof(int));
	cudaMalloc((void**)&temp_c,N*sizeof(int));
           c[i] = 0;
#ifdef TIMECUDA
	cudaEventRecord(start,0);
#else
#endif
 	cudaMemcpy(temp_a,a,N*sizeof(int),cudaMemcpyHostToDevice);
	cudaMemcpy(temp_b,b,N*sizeof(int),cudaMemcpyHostToDevice);
#ifdef TIMECUDA
	cudaEventRecord(stop,0);
	cudaEventSynchronize(stop);
	cudaEventElapsedTime(&elapsed_time_cpu_gpu,start,stop);
	printf("Time taken CUDA : %f \n",elapsed_time_cpu_gpu);
	cudaEventDestroy(start);
	cudaEventDestroy(stop);
#else
#endif
#ifdef TIMECPU
#else
#endif
#ifdef TIMECUDA
	cudaEventRecord(startadd,0);
#else
#endif
        add<<<N,N>>>(temp_a,temp_b,temp_c);
#ifdef TIMECUDA
	cudaEventRecord(stopadd,0);
	cudaEventSynchronize(stopadd);
	cudaEventElapsedTime(&elapsed_time_add,startadd,stopadd);
	printf("Time taken CUDA : %f \n",elapsed_time_add);
	cudaEventDestroy(startadd);
	cudaEventDestroy(stopadd);
#else
#endif
#ifdef TIMECPU
	elapsed_time = (float) ( timerStart - timerStop ) / CLOCKS_PER_SEC;
	printf("Time taken CPU  : %f \n",elapsed_time);
#else
#endif
#ifdef TIMECUDA
	cudaEventRecord(startback,0);
#else
#endif
	cudaMemcpy(c,temp_c, N*sizeof(int),cudaMemcpyDeviceToHost);
#ifdef TIMECUDA
	cudaEventRecord(stopback,0);
	cudaEventSynchronize(stopback);
	cudaEventElapsedTime(&elapsed_time_gpu_cpu,startback,stopback);
	printf("Time taken CUDA : %f ",elapsed_time_gpu_cpu);
	cudaEventDestroy(startback);
	cudaEventDestroy(stopback);
#else
#endif
/*        for (i=0; i<N; i++) {
            printf ("%f %f %f\n", a[i], b[i], c[i] );
	cudaFree(temp_a);
	cudaFree(temp_b);
	cudaFree(temp_c);
 	return 0;
My CPU version takes 20ms to execute.
In CUDA version, Copying data from device to host only takes 26 ms , add function takes 33 ms and back from host to device , it takes 29 ms. So around 80 ms.
Can anyone tell me the reason why its like this?
Its really strange. I thought CUDA is fast enough.
Please help me as I really want to work on CUDA.
Hello All,
include <stdio.h>
#include <time.h>
#include <math.h>
#include <stdlib.h>
#define N   10
    int tid = 0;
    while (tid < N) {
        tid += 1;
int main( void ) {
	float elapsed;
        int i;
        	c[i] = 0;
    	add( a, b, c );
	for (i=0; i<N;i++)
	return 0;
MY CUDA VERSION is
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <cuda.h>
#include "cutil.h"
#include <time.h>
#define TIMECUDA
//#define TIMECPU
#define N 10
    if (tid < N) {
int main( void ) {
    	long i;
#ifdef TIMECUDA
#else
#endif
#ifdef TIMECPU
	float elapsed_time;
#else
#endif
#ifdef TIMECPU
#else
#endif
#ifdef TIMECUDA
#else
#endif
           c[i] = 0;
#ifdef TIMECUDA
#else
#endif
#ifdef TIMECUDA
#else
#endif
#ifdef TIMECPU
#else
#endif
#ifdef TIMECUDA
#else
#endif
#ifdef TIMECUDA
#else
#endif
#ifdef TIMECPU
#else
#endif
#ifdef TIMECUDA
#else
#endif
#ifdef TIMECUDA
#else
#endif
	cudaFree(temp_a);
	cudaFree(temp_b);
	cudaFree(temp_c);
 	return 0;
Where to start… You are incorrectly using and interpreting the timing in both of those examples. Your cuda version is nonsensical in several repsects, and It would suggest that it is follow to draw conclusions on the relative performance of either piece of hardware when your code does such a trivial amount of total calculation.
Thanks for the reply, but can you please be specific…
In the first version, I am trying to extract the time taken by add function. In CUDA version, I did the same.Sorry but I am not able to understand the reply of yours.
Please explain as I am new to CUDA.
Or if possible can you tell me where am I doing the mistake in CUDA version.
