Performance in basic algorithm Why isn't faster?
I’ve been trying to make faster a piece of code that takes 100000 floats and subtracts 1 to each one.
Comparing the GPU time and CPU time it takes almost the same (including time of cudaMemcpy).
GPU Time: 1.439671 ms
CPU Time: 1.16542 ms
MemCpy Time: 1.4 ms
GPU Time without Memcpy: 0.0381
Why it isn’t faster when I include the CudaMemcpy (thtat is has to be included in the time)?
Here is the code:
[codebox] // KERNEL
global void square_array(float *a, int N)
int idx = blockIdx.x * blockDim.x + threadIdx.x;
if (idx<N) a[idx] = a[idx] -1;
// MAIN
int main(void)
float *a_h, *a_d; // Pointer to host & device arrays
const int num = 100000; // Number of elements in arrays
unsigned int hTimer; // Timer counter
size_t size = num * sizeof(float);
a_h = (float *)malloc(size); // Allocate array on host
cudaMalloc((void **) &a_d, size); // Allocate array on device
CUT_SAFE_CALL( cutCreateTimer(&hTimer) );
// Initialize host array and copy it to CUDA device
for (int i=0; i<num; i++)
	a_h[i] = (float)i;
cudaMemcpy(a_d, a_h, size, cudaMemcpyHostToDevice);
// Do calculation on device:
int block_size = 4;
int n_blocks = num/block_size + (num%block_size == 0 ? 0:1);
CUT_SAFE_CALL( cutResetTimer(hTimer) );
CUT_SAFE_CALL( cutStartTimer(hTimer) );
square_array <<< n_blocks, block_size >>> (a_d, num);
CUT_SAFE_CALL( cutStopTimer(hTimer) );
// Retrieve result from device and store it in host array
cudaMemcpy(a_h, a_d, sizeof(float)*num, cudaMemcpyDeviceToHost);
printf(“GPU time: %f msecs.\n”, cutGetTimerValue(hTimer));
getchar();
// Print results
	printf("%d %f\n", i, a_h[i]);
getchar();
Filtro1CPU(a_h,num);
printf(“CPU time: %f msecs.\n”, cutGetTimerValue(hTimer));
getchar();
// Cleanup
free(a_h); cudaFree(a_d);
CUT_SAFE_CALL( cutDeleteTimer(hTimer) );
} [/codebox]
I’ll be very gratefull f someone helps me.
Cya
you need to include a cudaThreadSynchronize after your kernel call if you want to accurately time things.
Now the GPU takes more time to process!!
Why does it happen?
Ty
Kernel call Overhead.
The GPU is only faster when it processes quite a large chunk of data at once. Also you
need to watch that you’re using the GPU’s capabilities fully. This means making
sure memory access is coalesced and you used shared memory for speed-up where
possible.
In your particular kernel I’d say you are not doing enough work per thread to obtain
a speed-up. A simple addition or subtraction is not OK.
Try adding or subtracting 16 consecutive values per thread (no loops please - everything
unrolled).
Christian
I added like 200 values just to test and now it is a lot faster!!!
Thx!!!
