Greetings,
I’ve been trying the new HPC SDK for a while now, both locally on my PC and on a POWER9 cluster. Although it’s mostly working fine, we have had an issue with the openMPI package provided: if compiling a program with it, then I cannot run it without the “mpirun -np *” command, as it complains:
[lucas-Precision-7730:12307] [[INVALID],INVALID] ORTE_ERROR_LOG: A system-required executable either could not be found or was not executable by this user in file ../../../../../orte/mca/ess/singleton/ess_singleton_module.c at line 572
[lucas-Precision-7730:12307] [[INVALID],INVALID] ORTE_ERROR_LOG: A system-required executable either could not be found or was not executable by this user in file ../../../../../orte/mca/ess/singleton/ess_singleton_module.c at line 172
Sorry! You were supposed to get help about:
orte_init:startup:internal-failure
But I couldn’t open the help file:
/proj/nv/libraries/Linux_x86_64/openmpi4/2020/195106-rel/share/openmpi/help-orte-runtime: No such file or directory. Sorry!
mpi_init:startup:internal-failure
/proj/nv/libraries/Linux_x86_64/openmpi4/2020/195106-rel/share/openmpi/help-mpi-runtime.txt: No such file or directory. Sorry!
*** An error occurred in MPI_Init
*** on a NULL communicator
*** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
*** and potentially your MPI job)
[lucas-Precision-7730:12307] Local abort before MPI_INIT completed completed successfully, but am not able to aggregate error messages, and not able to guarantee that all other processes were killed!
Now, I’ve installed the package as recommended in the documentation, and set the proper environment variables as specified by it as well, at least on my own PC. Is it possible that I am missing some PATH, or is the mpi package provided poorly configured? I’ve tried with both 3.1.5 and 4.0.2, with identical results. Again, if i run the binary with mpirun -np 1, it runs perfectly, but for our code we need to make sure it can be ran without it. Any help would be appreciated!
In any case, thank you very much!
