Huda22
August 23, 2022, 1:08pm
1
I have two programs in C++.
one of them MPI + OPENACC (1)
the other MPI+PENACC+OPENMP (2)
I am working on Ubuntu 20.04.4
NVC
First I try : (1)
mpic++ -Minfo=accel -fast -acc -ta=tesla mpi_isend_error_4_tested.cpp
g++: error: unrecognized command line option ‘-Minfo=accel’
g++: error: unrecognized command line option ‘-fast’; did you mean ‘-Ofast’?
g++: error: unrecognized command line option ‘-acc’
g++: error: unrecognized command line option ‘-ta=tesla’
What is the correct compile statment to run:
(1) MPI + OPENACC
(2) MPI+PENACC+OPENMP
Hi Huda22,
Looks like your mpic++ is configured for use with the g++ compiler. You need to use one that’s configured for use with nvc++.
We do ship several MPI with the NVHPC SDK, located under “<nvhpc_base_install>/Linux_x86_64//comm_libs”, which you can use.
-Mat
Huda22
August 24, 2022, 10:50am
3
Thank you very much for the quick reply
This environment is new to me and I don’t have a background so Ubuntu is new to me
I tried to cancel the existing version through the following instructions and re-download it again, but to no avail
Can someone help me on how to configure MPI to work with NVC
sudo apt autoremove mpi
sudo apt-get install libopenmpi-dev
sudo apt-get install mpi
the same problem arise
mpic++ -I/opt/nvidia/hpc_sdk/Linux_x86_64/21.11/comm_libs/mpi/include -L/opt/nvidia/hpc_sdk/Linux_x86_64/21.11/comm_libs/mpi/lib -Minfo=accel -fast -acc -ta=tesla mpi_test.cpp -o tt
You need to either set your PATH to include the MPI bin directory that ships with the NV HPC SDK, or build you’re own MPI with nvc++. Some MPI implementations allow you to change which compiler to use, for example with OpenMPI you’d set this via the OMPI_CXX environment variable (see: FAQ: Compiling MPI applications ). However, the mpi drivers will still add implicit flags so this doesn’t always work well.
To change your environment variables on Linux, it will depend on which shell you’re using. For Bash and it’s derivatives you’d use the “export” command, while for Csh, you’d use ‘setenv’.
For example:
export PATH=/opt/nvidia/hpc_sdk/Linux_x86_64/21.11/comm_libs/mpi/bin:$PATH
You’ll also want to set the LD_LIBRARY_PATH so the correct runtime libraries are used:
export LD_LIBRARY_PATH=/opt/nvidia/hpc_sdk/Linux_x86_64/21.11/comm_libs/mpi/lib:$LD_LIBRARY_PATH
Hope this helps,
Mat
Huda22
August 24, 2022, 5:47pm
5
Thank you so much
It works
