[mm5v3k@cl2master test]$ ./kenia.deck
(cd Run; make -i -r mmlif);
make[1]: Entering directory /data/mm5v3k/mm5v3-kenia/MM5/Run' cat < oparam > mmlif cat < lparam >> mmlif echo " IFRAD = echo “2,0,0,0,0”|cut -d, -f1,">>mmlif echo " ICUPA = "6,6,1,1,1,1,1,1,1,1",">>mmlif echo " IMPHYS = "4,4,1,1,1,1,1,1,1,1" ,">>mmlif echo " IBLTYP = "5,5,0,0,0,0,0,0,0,0",">>mmlif echo " ISHALLO = "0,0,0,0,0,0,0,0,0,0",">>mmlif echo " IPOLAR = 0,">>mmlif echo " ISOIL = 1,">>mmlif if [ ""linux"" = "IBM" ]; then \ echo " / ">>mmlif; \ elif [ ""linux"" = "sp2" ]; then \ echo " / ">>mmlif; \ elif [ ""linux"" = "HP" ]; then \ echo ' $END '>>mmlif; \ else \ echo " &END ">>mmlif; \ fi; cat < nparam >> mmlif cat < pparam >> mmlif cat < fparam >> mmlif make[1]: Leaving directory /data/mm5v3k/mm5v3-kenia/MM5/Run’
This version of mm5.deck stops after creating namelist file mmlif.
Please run code manually.
Mon Oct 27 16:54:06 EST 2008
running /data/mm5v3k/mm5v3-kenia/MM5/Run/mm5.mpp on 8 LINUX ch_p4 processors
Created /data/mm5v3k/mm5v3-kenia/MM5/Run/PI1830
node1 – rsl_nproc_all 8, rsl_myproc 0
node2 – rsl_nproc_all 8, rsl_myproc 1
node3 – rsl_nproc_all 8, rsl_myproc 2
node5 – rsl_nproc_all 8, rsl_myproc 4
node6 – rsl_nproc_all 8, rsl_myproc 5
node8 – rsl_nproc_all 8, rsl_myproc 7
node4 – rsl_nproc_all 8, rsl_myproc 3
node7 – rsl_nproc_all 8, rsl_myproc 6
rm_l_3_23458: (1969.804688) net_send: could not write to fd=5, errno = 32
rm_l_7_2332: (1968.929688) net_send: could not write to fd=5, errno = 32
rm_l_1_4222: (1970.253906) net_send: could not write to fd=5, errno = 32
rm_l_2_3760: (1970.035156) net_send: could not write to fd=7, errno = 32
rm_l_4_2499: (1969.601562) net_send: could not write to fd=5, errno = 32
rm_l_5_2746: (1969.371094) net_send: could not write to fd=5, errno = 32
P4 procgroup file is /data/mm5v3k/mm5v3-kenia/MM5/Run/PI1830.
