I use PGI worktation 2010, centos X64. I compile the example in /opt/pgi/linux86-64/10.3/EXAMPLES/MPI/mpihello, then type
mpirun -np 3 mpihello
Hello world! I'm node 0
what’s wrong with it? if you compile it with mpif90, the result is right. [/code]
Hi siwuxie,
How did you compile the version with the wrong answer? Which MPI version are you using?
I use the command line
pgfortran mpihello.f -Mmpi=mpich1 -o mpihello
According to the user’s guide, compiler will use mpich1 installed in pgi’s folder.
And if you compile it with mpif90 of MPICH2
mpif90 -o mpihello mpihello.f
mpirun -n 3 mpihello
Hello world! I'm node 2
Hello world! I'm node 1
So mpirun can get right result, and this may not be the problem of SSH. I’ve installed PGI again, but still can’t get right anwser. [/code]
tull
4
Try this version of mpihello.f
% more mpihello.f
program hello
include ‘mpif.h’
integer ierr, myproc,hostnm, nprocs
character*64 hostname
call mpi_init(ierr)
CALL MPI_COMM_SIZE(MPI_COMM_WORLD, nprocs, ierr)
call mpi_comm_rank(MPI_COMM_WORLD, myproc, ierr)
ierr=setvbuf3f(6,2,0)
ierr=hostnm(hostname)
write(6,100) myproc,nprocs,hostname
100 format(1x,“hello - I am process”,i3," of", i3, " on host ",A32)
call mpi_finalize(ierr)
end
I am assuming you have release 10.3 installed and you said ‘yes’
to MPICH install in /opt/pgi
% pgfortran -o mpihello mpihello.f -Mmpi=mpich1
%/opt/pgi/linux86/10.3/mpi/mpich/bin/mpirun -np 4 mpihello
to make sure you are using the mpich1 version of mpirun.
dave
