I installed PGI workstaiton 10.3 on centos 5.5 x64. I intend to combine CUDA fortran, cula and mpi together. I have installed mpich2, test results is right.I want to use MPICh2, becuase my mpich1 of pgi installed can’t work, so i make a siterc file in bin folder both in x86 & x64.
my siterc file
set MPIUDIR=/opt/mpich2-install;
I wrote a simple mpihello.cuf to test, but may be have some wrong with lib dependence.
my siterc file
program hello
use cudafor
use mpi
integer :: istat,numdevices
integer :: ierr,cpuid,numprocs,namelen
character* (mpi_max_processor_name) processor_name
integer :: id,gpuid
type(cudadeviceprop) :: prop
istat=cudaGetDeviceCount(numdevices)
call mpi_init(ierr)
call mpi_comm_rank(mpi_comm_world,cpuid,ierr)
call mpi_comm_size(mpi_comm_world,numprocs,ierr)
call mpi_get_processor_name(processor_name,namelen,ierr)
gpuid=mod(cpuid,numdevices)
istat=cudaSetDevice(gpuid)
istat=cudaGetDeviceProperties(prop,gpuid)
if (cpuid==0) write(*,"(a9,i2,a12)") "There are",numdevices,"GPU device!"
write (*,"(a21,i2,a4,i1,a4,a30)"), "Hello world! process ",cpuid," of ",numprocs," on ",processor_name
write (*,"(a6,i2)") "GPU id",gpuid
write (*,"(a12,a20)") "Device name ",prop%name
call mpi_finalize(ierr)
end
my makefile
FC=pgfortran
#Change to -Mmpi2 for MPICH2
MPI=-Mmpi=mpich2
#add cuf
CUDA=-ta=nvidia -Mcuda
#lib
LIB=-L/usr/local/cula/lib64 -lcula_pgfortran
mpihello:
$(FC) $(MPI) $(LIB) -o mpihello mpihello.cuf
error information
pgfortran -Mmpi=mpich2 -L/usr/local/cula/lib64 -lcula_pgfortran -o mpihello mpihello.cuf
/opt/mpich2-install/lib/libmpich.a(init.o): In function `MPI_Init':
init.c:(.text+0x38): undefined reference to `MPL_env2str'
init.c:(.text+0x55): undefined reference to `MPL_env2bool'
/opt/mpich2-install/lib/libmpich.a(initthread.o): In function `MPI_Init_thread':
initthread.c:(.text+0x4b1): undefined reference to `MPL_env2bool'
/opt/mpich2-install/lib/libmpich.a(param_vals.o): In function `MPIR_Param_init_params':
param_vals.c:(.text+0xf): undefined reference to `MPL_env2int'
param_vals.c:(.text+0x27): undefined reference to `MPL_env2int'
param_vals.c:(.text+0x3f): undefined reference to `MPL_env2int'
param_vals.c:(.text+0x57): undefined reference to `MPL_env2int'
param_vals.c:(.text+0x6f): undefined reference to `MPL_env2int'
/opt/mpich2-install/lib/libmpich.a(param_vals.o):param_vals.c:(.text+0x87): more undefined references to `MPL_env2int' follow
param_vals.c:(.text+0x327): undefined reference to `MPL_env2bool'
param_vals.c:(.text+0x33f): undefined reference to `MPL_env2bool'
param_vals.c:(.text+0x357): undefined reference to `MPL_env2bool'
param_vals.c:(.text+0x36f): undefined reference to `MPL_env2bool'
param_vals.c:(.text+0x387): undefined reference to `MPL_env2bool'
/opt/mpich2-install/lib/libmpich.a(param_vals.o):param_vals.c:(.text+0x39f): more undefined references to `MPL_env2bool' follow
param_vals.c:(.text+0x3e7): undefined reference to `MPL_env2int'
param_vals.c:(.text+0x3ff): undefined reference to `MPL_env2int'
param_vals.c:(.text+0x417): undefined reference to `MPL_env2bool'
param_vals.c:(.text+0x42f): undefined reference to `MPL_env2bool'
param_vals.c:(.text+0x447): undefined reference to `MPL_env2bool'
param_vals.c:(.text+0x45f): undefined reference to `MPL_env2bool'
param_vals.c:(.text+0x477): undefined reference to `MPL_env2int'
param_vals.c:(.text+0x48f): undefined reference to `MPL_env2int'
param_vals.c:(.text+0x4a7): undefined reference to `MPL_env2int'
param_vals.c:(.text+0x4bf): undefined reference to `MPL_env2int'
param_vals.c:(.text+0x4d7): undefined reference to `MPL_env2str'
param_vals.c:(.text+0x4ef): undefined reference to `MPL_env2str'
param_vals.c:(.text+0x507): undefined reference to `MPL_env2bool'
param_vals.c:(.text+0x51f): undefined reference to `MPL_env2bool'
param_vals.c:(.text+0x537): undefined reference to `MPL_env2bool'
param_vals.c:(.text+0x54f): undefined reference to `MPL_env2bool'
param_vals.c:(.text+0x567): undefined reference to `MPL_env2bool'
/opt/mpich2-install/lib/libmpich.a(param_vals.o):param_vals.c:(.text+0x57f): more undefined references to `MPL_env2bool' follow
/opt/mpich2-install/lib/libmpich.a(mpid_vc.o): In function `MPIDI_Populate_vc_node_ids':
mpid_vc.c:(.text+0x2d2): undefined reference to `MPL_env2int'
mpid_vc.c:(.text+0x2e4): undefined reference to `MPL_env2int'
mpid_vc.c:(.text+0x30b): undefined reference to `MPL_env2bool'
/opt/mpich2-install/lib/libmpich.a(tcp_init.o): In function `MPID_nem_tcp_bind':
tcp_init.c:(.text+0x18f): undefined reference to `MPL_env2range'
siwuxie
