I am attempting to set MTU size to 9000 on a TX2 and the following works:
sudo ifconfig eth0 mtu 9000 up
but when I change my /etc/network/interfaces.d/myconfig to:
auto eth0
iface eth0 inet static
address 192.168.10.81
netmask 255.255.255.0
gateway 192.168.10.1
mtu 9000
ifconfig before the command:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.10.81 netmask 255.255.255.0 broadcast 192.168.10.255
ether 00:04:4b:8d:34:a2 txqueuelen 1000 (Ethernet)
RX packets 1255 bytes 178127 (178.1 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 683 bytes 187108 (187.1 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 40
and after:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 9000
RX packets 1522 bytes 211713 (211.7 KB)
TX packets 826 bytes 225817 (225.8 KB)
device interrupt 40
it just refuses to take the mtu 9000
in the interfaces file. I confirmed it is loading the interfaces file by changing the static IP back and forth and rebooting, but it won’t take the 9000. any thoughts?
