multi nested loop, any hints?
I need to calculate the roots of
. In this case, multi-nested loop (>4) is need. How to let GPU calculate it with the device code parallely and efficently?
thanks
currently I have a stupid solution: make and fill a array c in host code first, then this array is used as a 2-d array
for example, for 4-order equation
//this is code totally on cpu
for(i=0;i<I;i++)
for(j=0;j<J;j++)
for(k=0;k<K;k++)
for(l=0;l<L;l++)
for(m=0;m<M;m++)
fillRootArray(getroot(i,j,k,l,m));
//this code use cpu and gpu
//but I have to fill the array by CPU code
//and the "some idx" is hard to write if I get more dimension
__host__ fillarray()
for(i=0;i<I;i++)
for(j=0;j<J;j++)
for(k=0;k<K;k++)
for(l=0;l<L;l++)
for(m=0;m<M;m++)
c[some idx]=[i,j,k,l,m];
// as a result c=[[0,0,0,0,0];[0,0,0,0,1];.....;[I-1, J-1, K-1, L-1, M-1]];
__device__ getroot()
fillRootArray(getroot(c));
