Multi rtsp stream corrupted due to performance limitation
• Hardware Platform (Jetson / GPU) Jetson NX
• DeepStream Version 6.1
• JetPack Version (valid for Jetson only) 34.1.1
• TensorRT Version 8.4.0.11
• NVIDIA GPU Driver Version (valid for GPU only) 11.4
• Issue Type( questions, new requirements, bugs) questions
We are using deepstream-test5-app to create an application, pull streams from multiple RTSP and perform detection tracking, and finally push the tracking results out of the box. We found that when 8-channel streaming is performed and NvDCF or Deepsort is used, the stream will fall back and the frame will be stuck, such as the problem of read I frame as follow. But it works fine if only 4 stream is pulled, or 8 stream only uses IOU tracking.
Our config file
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=0
rows=2
columns=2
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=4
uri=rtsp://*******/h264/ch1/stream3/av_stream
num-sources=1
gpu-id=0
nvbuf-memory-type=0
drop-frame-interval=0
[source1]
enable=1
type=4
num-sources=1
gpu-id=0
nvbuf-memory-type=0
[source2]
enable=1
type=4
uri=rtsp:/*******/h264/ch1/stream3/av_stream
num-sources=1
gpu-id=0
nvbuf-memory-type=0
p video stream.
smart-rec-interval=20
[source3]
enable=1
type=4
num-sources=1
gpu-id=0
nvbuf-memory-type=0
[source4]
enable=1
type=4
uri=rtsp:/*******/h264/ch1/sub/av_stream
num-sources=1
gpu-id=0
nvbuf-memory-type=0
[source5]
enable=1
type=4
num-sources=1
gpu-id=0
nvbuf-memory-type=0
drop-frame-interval=1
[source6]
enable=1
type=4
num-sources=1
gpu-id=0
nvbuf-memory-type=0
[source7]
enable=1
type=4
num-sources=1
gpu-id=0
nvbuf-memory-type=0
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File
type=1
sync=1
source-id=0
gpu-id=0
enc-type = 1
nvbuf-memory-type=0
[sink1]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvdrmvideosink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM   - Custom schema payload
msg-conv-payload-type=0
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_kafka_proto.so
msg-broker-conn-str=
topic=nxtest
#Optional:
#msg-broker-config=../../deepstream-test4/cfg_kafka.txt
[sink2]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
source-id=0
sync=0
bitrate=4000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
# set below properties in case of RTSPStreaming
rtsp-port=9091
udp-port=5400
[sink3]
enable=1
type=4
source-id=1
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=9090
udp-port=5401
[sink4]
enable=1
type=4
source-id=2
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=9092
udp-port=5402
[sink5]
enable=1
type=4
source-id=3
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=9093
udp-port=5403
[sink6]
enable=1
type=4
source-id=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=9094
udp-port=5404
[sink7]
enable=1
type=4
source-id=5
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=9095
udp-port=5405
[sink8]
enable=1
type=4
source-id=6
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=9096
udp-port=5406
[sink9]
enable=1
type=4
source-id=7
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
rtsp-port=9097
udp-port=5407
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=8
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=60000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
[primary-gie]
enable=1
gpu-id=0
batch-size=8
## 0=FP32, 1=INT8, 2=FP16 mode
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;1;1;1
bbox-border-color3=0;1;0;1
nvbuf-memory-type=0
interval=0
gie-unique-id=1
model-engine-file=/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b8_gpu0_int8.engine
labelfile-path=../../../../../samples/models/Primary_Detector/labels.txt
config-file=../../../../..samples/configs/deepstream-app/config_infer_primary.txt
#infer-raw-output-dir=../../../../../samples/primary_detector_raw_output/
[tracker]
enable=1
# For NvDCF and DeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
# ll-config-file required to set different tracker types
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_IOU.yml
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml
ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_DeepSORT.yml
gpu-id=0
enable-batch-process=4
enable-past-frame=1
display-tracking-id=1
Is this due to a performance bottleneck?
Or are there any settings that can improve this phenomenon and achieve real-time performance as much as possible? Our rtsp are all 25fps
Anothor addition question?The fan control of this board can not be seem, I do not know what happened.
I can not find the pwn-fan in the sysytem
Seems hit the performance bottleneck. Do you set the power mode to the highest performance?
Yes
I have tried other power modes, but it also is not fine.
So it is performance limitation. IOU tracker has the best performance.
