• Hardware Platform (Jetson / GPU) Jetson Xavier NX
• DeepStream Version DeepStream 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 8.0.1-1
• Issue Type( questions, new requirements, bugs) questions
I am currently running deepstream-app on Jetson Nx Xavier board.
In the Jetson device, I also run the Node.js application with node-rtsp-stream, which runs the ffmpeg with “rtsp_transport tcp” option. Also, there is an external webserver for web dashboard, and this webserver is also using ffmpeg with “rtsp_transport tcp” option for getting rtsp video stream from deepstream-app.
When running this application, we found that the quality of the video that is generated by Node.js server on the Jetson device is good enough, however, the quality of video in webserver is not that much good.
So, the questions are:
Since we uses ffmpeg with “rtsp_transport tcp” option, we are receiving rtsp stream via tcp. However it seems like the deepstream-app only uses udp sink for rtsp streaming. How could this work? Does rtsp sink (or rtsp server) internally uses tcp for transmission?
Do you think the reason of bad video quality in webserver is because we are connected 2 receivers at 1 rtsp sink? Or are we missing something? Below is the config that we used for deepstream-app.
# Copyright (c) 2019-2020, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
# gie-kitti-output-dir=./streamscl
# kitti-track-output-dir=./kitti_track
[tiled-display]
enable=1
rows=1
columns=2
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=4
uri=rtsp://192.168.17.100:554/profile2/media.smp
num-sources=1
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
smart-record=2
smart-rec-dir-path=/opt/nvidia/deepstream/deepstream-6.0/sources/objectDetector_Yolo/sr
smart-rec-file-prefix=sr0
smart-rec-cache=60
#smart-rec-default-duration= 30
[source1]
enable=1
type=4
uri=rtsp://192.168.17.101:554/profile2/media.smp
num-sources=1
gpu-id=0
cudadec-memtype=0
smart-record=2
smart-rec-file-prefix=sr1
smart-rec-cache=60
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
nvbuf-memory-type=0
overlay-id=1
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=2
source-id=0
#when run deepstream-app
output-file=test.mp4
width=1280
height=720
[sink2]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=2560000
profile=4
# set below properties in case of RTSPStreaming
rtsp-port=8123
udp-port=5400
udp-buffer-size=2560000
width=1280
height=720
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=2
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1280
height=720
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
#model-engine-file=model_b1_gpu0_int8.engine
labelfile-path=labels.txt
batch-size=2
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=2
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV3.txt
[tracker]
enable=1
# For NvDCF and DeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream-6.0/lib/libnvds_nvmultiobjecttracker.so
# ll-config-file required to set different tracker types
# ll-config-file=../../samples/configs/deepstream-app/config_tracker_IOU.yml
ll-config-file=../../samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
# ll-config-file=../../samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml
# ll-config-file=../../samples/configs/deepstream-app/config_tracker_DeepSORT.yml
gpu-id=0
enable-batch-process=1
enable-past-frame=1
display-tracking-id=1
[tests]
file-loop=0
