RTSP stream sent by rtspclientsink doesn’t play in deepstream 6.2.
NVIDIA GeForce RTX 3060 Laptop GPU
• DeepStream Version
6.2.0
• TensorRT Version
8.5.2.2
520.61.05
bug
Start rtsp-simple-server with the default configuration:
wget https://github.com/aler9/rtsp-simple-server/releases/download/v0.21.5/rtsp-simple-server_v0.21.5_linux_amd64.tar.gz
tar -xvzf rtsp-simple-server_v0.21.5_linux_amd64.tar.gz
./rtsp-simple-server
Start a pipeline to send RTSP stream to the server:
docker run \
--name test \
--rm -it \
--gpus all \
--entrypoint gst-launch-1.0 \
nvcr.io/nvidia/deepstream:6.2-base \
videotestsrc ! \
'video/x-raw,width=1280,height=720,framerate=30/1' ! \
nvvideoconvert ! \
nvv4l2h264enc ! \
h264parse ! \
rtspclientsink location='rtsp://172.17.0.1:8554/stream'
Try to receive the stream with ffplay:
ffplay 'rtsp://localhost:8554/stream'
ffplay doesn’t play the stream
ffplay logs
ffplay version 4.4.2-0ubuntu0.22.04.1 Copyright (c) 2003-2021 the FFmpeg developers
built with gcc 11 (Ubuntu 11.2.0-19ubuntu1)
configuration: --prefix=/usr --extra-version=0ubuntu0.22.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 70.100 / 56. 70.100
libavcodec 58.134.100 / 58.134.100
libavformat 58. 76.100 / 58. 76.100
libavdevice 58. 13.100 / 58. 13.100
libavfilter 7.110.100 / 7.110.100
libswscale 5. 9.100 / 5. 9.100
libswresample 3. 9.100 / 3. 9.100
libpostproc 55. 9.100 / 55. 9.100
[rtsp @ 0x7f3ca0000cc0] decoding for stream 0 failed= 0B f=0/0
Input #0, rtsp, from 'rtsp://localhost:8554/stream':
Metadata:
title : Stream
Duration: N/A, bitrate: N/A
Stream #0:0: Video: h264 (Constrained Baseline), yuv420p(tv, bt709, progressive), 1280x720 [SAR 1:1 DAR 16:9], 30 fps, 30 tbr, 90k tbn, 60 tbc
ffplay plays an RTSP stream from deepstream 6.1.1 (nvcr.io/nvidia/deepstream:6.1.1-base) and there is no error [rtsp @ 0x7f3ca0000cc0] decoding for stream 0 failed.
