• Hardware Platform (Jetson / GPU) GPU (in a Docker container)
• DeepStream Version 6.2 (from Docker image nvcr.io/nvidia/deepstream:6.2-base)
• JetPack Version (valid for Jetson only) N/A
• TensorRT Version N/A
• NVIDIA GPU Driver Version (valid for GPU only) 525.125.06
• Issue Type (questions, new requirements, bugs) Question/troubleshooting
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) N/A
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) N/A
My team is using DeepStream with gstreamer inside a Docker container to process incoming RTSP/H.264 video streams (e.g. from external cameras), turn the incoming frames into NumPy arrays, do some processing on these arrays, and then construct them back into frames to push into an RTSP/H.264 output stream. The RTSP server is running in a separate Docker container on the host machine, exposed to the host network. The goal is for our RTSP output stream to look and behave exactly as if it were a regular camera stream. However, we’re having some issues. The RTSP stream works, and VLC can play it (with some visual artifacts), but seemingly nothing else can play the stream successfully - most notably FFMPEG (via the ffplay command).
I do not believe Docker is related to the issue, since I am able to produce an alternative RTSP stream within the same environment NOT using gstreamer, with no issues (see below).
What doesn’t work (using gstreamer):
Here is our output pipeline (for testing, using a 640x480 stream, 30fps):
appsrc name=input do-timestamp=true is-live=true block=true format=3 max-bytes=73728000 ! video/x-raw,format=BGRx,framerate=30/1,width=640,height=480 ! nvvideoconvert ! video/x-raw(memory:NVMM),format=I420,framerate=30/1,width=640,height=480 ! nvv4l2h264enc bitrate=4000000 profile=4 ! rtspclientsink protocols=4 location=rtsp://10.77.0.135:8554/out1
I have an RTSP server (from Docker image bluenviron/mediamtx v1.1.1) running at 10.77.0.135:8554.
When I try to play this stream with FFMPEG, here’s what I see:
FFMPEG command: ffplay rtsp://10.77.0.135:8554/out1
Result: it manages to pull the stream information, seemingly correctly, but it hangs after this output and is not able to play it:
ffplay version 4.4.2-0ubuntu0.22.04.1 Copyright (c) 2003-2021 the FFmpeg developers
built with gcc 11 (Ubuntu 11.2.0-19ubuntu1)
configuration: --prefix=/usr --extra-version=0ubuntu0.22.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 70.100 / 56. 70.100
libavcodec 58.134.100 / 58.134.100
libavformat 58. 76.100 / 58. 76.100
libavdevice 58. 13.100 / 58. 13.100
libavfilter 7.110.100 / 7.110.100
libswscale 5. 9.100 / 5. 9.100
libswresample 3. 9.100 / 3. 9.100
libpostproc 55. 9.100 / 55. 9.100
[rtsp @ 0x7f9bbc000cc0] decoding for stream 0 failed= 0B f=0/0
Input #0, rtsp, from 'rtsp://10.77.0.135:8554/out1':
Metadata:
title : Session streamed with GStreamer
Duration: N/A, bitrate: N/A
Stream #0:0: Video: h264 (High), yuv420p(tv, smpte170m/smpte170m/bt709, progressive), 640x480 [SAR 1:1 DAR 4:3], 30 fps, 30 tbr, 90k tbn, 60 tbc
nan M-V: nan fd= 0 aq= 0KB vq= 0KB sq= 0B f=0/0
What works (without gstreamer):
I have another RTSP stream, which takes the exact same frames as NumPy arrays, but instead of passing them to the appsrc for the gstreamer pipeline above, it sends them to another non-gstreamer RTSP streaming solution (called Vidgear, but it’s basically just a wrapper of an FFMPEG command). It sends the stream to the same RTSP server, as out2 instead of out1. This one works perfectly fine, and the only difference between the two is whether it’s using the DeepStream/gstreamer pipeline or Vidgear/FFMPEG to create the stream.
FFMPEG command: ffplay rtsp://10.77.0.135:8554/out2
Result: There are some warnings (I believe due to i-frames, etc.), but after a few seconds the stream plays successfully (the last line keeps updating as it plays):
[h264 @ 0x7fb870006300] co located POCs unavailableq= 0B f=0/0
Input #0, rtsp, from 'rtsp://10.77.0.135:8554/out2':= 0B f=0/0
Metadata:
title : No Name
Duration: N/A, start: 1.130533, bitrate: N/A
Stream #0:0: Video: h264 (High), yuv420p(progressive), 640x480, 30 fps, 30 tbr, 90k tbn, 60 tbc
[h264 @ 0x7fb870044b80] co located POCs unavailable
[h264 @ 0x7fb870351000] co located POCs unavailable
[h264 @ 0x7fb870338580] mmco: unref short failure
7.68 M-V: 0.017 fd= 0 aq= 0KB vq= 195KB sq= 0B f=0/0
As a reminder, VLC is able to play both of these streams successfully (though the artifacting behavior is different between the two). In contrast, FFMPEG can successfully play out2, but not out1 (which is the DeepStream/gstreamer one).
What I notice looking at these two FFMPEG outputs:
- For
out1it can’t get a “start” time, presumably because it isn’t receiving frames correctly - The stream information is almost identical for both, except that for
out1it showsyuv420p(tv, smpte170m/smpte170m/bt709, progressive), while forout2it only showsyuv420p(progressive). Also, forout1it shows a SAR/DAR, whileout2does not. out1shows an error:[rtsp @ 0x7f9bbc000cc0] decoding for stream 0 failed= 0B f=0/0which I believe is the root of the problemout2shows a few warnings, but then it starts playing successfully and seems to be fine
My overall question:
I want the DeepStream/gstreamer RTSP stream (out1) to behave the same way as out2. Are there any issues or changes to my pipeline that could resolve this? Or could the issue be an incompatibility with the gstreamer pipeline and the “mediamtx” RTSP server? Is it related to the DeepStream components, or gstreamer in general? I suspect the issue is closely related to the decoding for stream 0 failed error, but I am unsure what else to try after messing around with some of the pipeline components with no success.
