Thank you. These are the logs I get when it is not working (no matter whether I use uridecodebin or rtspsrc ! ... ! nvv4l2decoder) :
0:00:08.027100926 1 0x23ac9630 WARN v4l2 gstv4l2object.c:4430:gst_v4l2_object_probe_caps:<nvv4l2decoder0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:08.027167327 1 0x23ac9630 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7ec813b540 Failed to determine interlace mode
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
0:00:08.046334900 1 0x23aca630 WARN v4l2 gstv4l2object.c:4430:gst_v4l2_object_probe_caps:<nvv4l2decoder1:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:08.046485781 1 0x23aca630 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7ed40ddf40 Failed to determine interlace mode
0:00:08.053773070 1 0x23acb370 WARN v4l2 gstv4l2object.c:4430:gst_v4l2_object_probe_caps:<nvv4l2decoder2:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:08.054449267 1 0x23acb370 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7edc09f570 Failed to determine interlace mode
0:00:08.137650588 1 0x23ac9630 WARN v4l2 gstv4l2object.c:4430:gst_v4l2_object_probe_caps:<nvv4l2decoder0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:08.137717213 1 0x23ac9630 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7ec813b540 Failed to determine interlace mode
0:00:08.140341201 1 0x23ac9630 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event:<mask_sink> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:08.168530157 1 0x23acb370 WARN v4l2 gstv4l2object.c:4430:gst_v4l2_object_probe_caps:<nvv4l2decoder2:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:08.170108825 1 0x23acb370 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7edc09f570 Failed to determine interlace mode
0:00:08.186803707 1 0x23aca630 WARN v4l2 gstv4l2object.c:4430:gst_v4l2_object_probe_caps:<nvv4l2decoder1:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:08.187718595 1 0x23aca630 WARN v4l2 gstv4l2object.c:2372:gst_v4l2_object_add_interlace_mode:0x7ed40ddf40 Failed to determine interlace mode
0:00:08.193446319 1 0x23aa3770 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event:<door_sink> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:08.353377486 1 0x23ac9630 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event:<mask_sink> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:08.353690513 1 0x23acb370 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event:<mask_sink> stream-start event without group-id. Consider implementing group-id handling in the upstream elements
0:00:08.355205244 1 0x23ac9630 WARN v4l2videodec gstv4l2videodec.c:1632:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:08.357154476 1 0x23acb370 WARN v4l2videodec gstv4l2videodec.c:1632:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder2> Duration invalid, not setting latency
0:00:08.363934145 1 0x23aa3230 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<door_1_crop> transform could not transform video/x-raw(memory:NVMM), width=(int)2560, height=(int)1440, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)RGBA, batch-size=(int)3, num-surfaces-per-frame=(int)1 in anything we support
0:00:08.366391668 1 0x23aa3850 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<door_2_crop> transform could not transform video/x-raw(memory:NVMM), width=(int)2560, height=(int)1440, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)RGBA, batch-size=(int)3, num-surfaces-per-frame=(int)1 in anything we support
0:00:08.366655926 1 0x23aa38f0 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<door_3_crop> transform could not transform video/x-raw(memory:NVMM), width=(int)2560, height=(int)1440, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)RGBA, batch-size=(int)3, num-surfaces-per-frame=(int)1 in anything we support
0:00:08.367627709 1 0x23aca630 WARN v4l2videodec gstv4l2videodec.c:1632:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder1> Duration invalid, not setting latency
0:00:08.407117617 1 0x23acb370 WARN v4l2bufferpool gstv4l2bufferpool.c:1057:gst_v4l2_buffer_pool_start:<nvv4l2decoder2:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:08.413920166 1 0x7edc007e80 WARN v4l2bufferpool gstv4l2bufferpool.c:1503:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder2:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:08.416973598 1 0x23ac9630 WARN v4l2bufferpool gstv4l2bufferpool.c:1057:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:08.423810867 1 0x23aca630 WARN v4l2bufferpool gstv4l2bufferpool.c:1057:gst_v4l2_buffer_pool_start:<nvv4l2decoder1:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:08.435874641 1 0x7ed406d4a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1503:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:08.444422708 1 0x7ec87c4b70 WARN v4l2bufferpool gstv4l2bufferpool.c:1503:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder1:pool:src> Driver should never set v4l2_buffer.field to ANY
0:00:08.446323715 1 0x23aa3850 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<door_2_crop> transform could not transform video/x-raw(memory:NVMM), width=(int)2560, height=(int)1440, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)RGBA, batch-size=(int)3, num-surfaces-per-frame=(int)1 in anything we support
0:00:08.447651405 1 0x23aa3230 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<door_1_crop> transform could not transform video/x-raw(memory:NVMM), width=(int)2560, height=(int)1440, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)RGBA, batch-size=(int)3, num-surfaces-per-frame=(int)1 in anything we support
0:00:08.447865775 1 0x23aa3850 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<door_2_crop> transform could not transform video/x-raw(memory:NVMM), width=(int)2560, height=(int)1440, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)RGBA, batch-size=(int)3, num-surfaces-per-frame=(int)1 in anything we support
0:00:08.447600941 1 0x23aa38f0 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<door_3_crop> transform could not transform video/x-raw(memory:NVMM), width=(int)2560, height=(int)1440, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)RGBA, batch-size=(int)3, num-surfaces-per-frame=(int)1 in anything we support
0:00:08.448349075 1 0x23aa38f0 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<door_3_crop> transform could not transform video/x-raw(memory:NVMM), width=(int)2560, height=(int)1440, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)RGBA, batch-size=(int)3, num-surfaces-per-frame=(int)1 in anything we support
0:00:08.447991440 1 0x23aa3230 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<door_1_crop> transform could not transform video/x-raw(memory:NVMM), width=(int)2560, height=(int)1440, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)RGBA, batch-size=(int)3, num-surfaces-per-frame=(int)1 in anything we support
0:00:08.549132197 1 0x23aa4720 WARN nvstreammux_ntp gstnvstreammux_ntp.cpp:97:check_if_sys_rtcp_time_is_ntp_sync:<mux_0> warning: Either host or Source 2 seems to be out of NTP sync SYS TIME = 2020-12-04T14:54:39.003Z CALCULATED NTP TIME = 1970-01-01T00:00:00.000Z
2020-12-04 14:54:39 pervasive-desktop app[1] WARNING gst-library-error-quark: Either host or Source 2 seems to be out of NTP sync SYS TIME = 2020-12-04T14:54:39.003Z CALCULATED NTP TIME = 1970-01-01T00:00:00.000Z (5)/dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmultistream2/gstnvstreammux_ntp.cpp(97): check_if_sys_rtcp_time_is_ntp_sync (): /GstPipeline:pipeline0/GstNvStreamMux:mux_0
0:00:08.558628079 1 0x23aa3850 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<door_2_crop> transform could not transform video/x-raw(memory:NVMM), width=(int)2560, height=(int)1440, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)RGBA, batch-size=(int)3, num-surfaces-per-frame=(int)1 in anything we support
0:00:08.559802904 1 0x23aa3230 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<door_1_crop> transform could not transform video/x-raw(memory:NVMM), width=(int)2560, height=(int)1440, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)RGBA, batch-size=(int)3, num-surfaces-per-frame=(int)1 in anything we support
0:00:08.559715927 1 0x23aa38f0 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<door_3_crop> transform could not transform video/x-raw(memory:NVMM), width=(int)2560, height=(int)1440, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)20/1, format=(string)RGBA, batch-size=(int)3, num-surfaces-per-frame=(int)1 in anything we support
0:00:08.584179574 1 0x23aa4720 WARN nvstreammux_ntp gstnvstreammux_ntp.cpp:97:check_if_sys_rtcp_time_is_ntp_sync:<mux_0> warning: Either host or Source 1 seems to be out of NTP sync SYS TIME = 2020-12-04T14:54:39.038Z CALCULATED NTP TIME = 1970-01-01T00:00:00.000Z
2020-12-04 14:54:39 pervasive-desktop app[1] WARNING gst-library-error-quark: Either host or Source 1 seems to be out of NTP sync SYS TIME = 2020-12-04T14:54:39.038Z CALCULATED NTP TIME = 1970-01-01T00:00:00.000Z (5)/dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmultistream2/gstnvstreammux_ntp.cpp(97): check_if_sys_rtcp_time_is_ntp_sync (): /GstPipeline:pipeline0/GstNvStreamMux:mux_0
0:00:08.597247068 1 0x23aa4720 WARN nvstreammux_ntp gstnvstreammux_ntp.cpp:97:check_if_sys_rtcp_time_is_ntp_sync:<mux_0> warning: Either host or Source 0 seems to be out of NTP sync SYS TIME = 2020-12-04T14:54:39.051Z CALCULATED NTP TIME = 1970-01-01T00:00:00.000Z
2020-12-04 14:54:39 pervasive-desktop app[1] WARNING gst-library-error-quark: Either host or Source 0 seems to be out of NTP sync SYS TIME = 2020-12-04T14:54:39.051Z CALCULATED NTP TIME = 1970-01-01T00:00:00.000Z (5)/dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmultistream2/gstnvstreammux_ntp.cpp(97): check_if_sys_rtcp_time_is_ntp_sync (): /GstPipeline:pipeline0/GstNvStreamMux:mux_0
0:00:09.095631434 1 0x7f280034f0 WARN nvstreammux_ntp gstnvstreammux_ntp.cpp:97:check_if_sys_rtcp_time_is_ntp_sync:<mux_1> warning: Either host or Source 0 seems to be out of NTP sync SYS TIME = 2020-12-04T14:54:39.550Z CALCULATED NTP TIME = 1970-01-01T00:00:00.000Z
2020-12-04 14:54:39 pervasive-desktop app[1] WARNING gst-library-error-quark: Either host or Source 0 seems to be out of NTP sync SYS TIME = 2020-12-04T14:54:39.550Z CALCULATED NTP TIME = 1970-01-01T00:00:00.000Z (5)/dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmultistream2/gstnvstreammux_ntp.cpp(97): check_if_sys_rtcp_time_is_ntp_sync (): /GstPipeline:pipeline0/GstNvStreamMux:mux_1
I think the importan part is in transform could not transform video/x-raw(memory:NVMM).... Everything goes wrong when this message appears. Sometimes it displays a completely green frame and other times it just freezes in the first frame.
