Cannot send frame image of rtsp by mqtt
Jetson Orin NX
• DeepStream Version
DeepStream 7.0
JetPack 6.0
• TensorRT Version
TensorRT 8.6.2.3
NVIDIA UNIX Open Kernel Module for aarch64 540.3.0
I’m trying to send image and message from a rtsp by mqtt and also output a rtsp stream, but it doesn’t work. When I try to watch the output stream the stream crushes and I don’t get the message, but the app seems still running. Here’s my code I have problem with
def pgie_src_pad_buffer_probe(pad, info, u_data):
    frame_number = 0
    num_rects = 0
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
        except StopIteration:
            break
        frame_number = frame_meta.frame_num
        print("Frame Number=", frame_number)
        if ts_from_rtsp:
            ts = frame_meta.ntp_timestamp / 1000000000
            print("RTSP Timestamp:", datetime.datetime.utcfromtimestamp(ts).strftime('%Y-%m-%d %H:%M:%S'))
        obj_meta_list = frame_meta.obj_meta_list
        while obj_meta_list is not None:
            try:
                obj_meta = pyds.NvDsObjectMeta.cast(obj_meta_list.data)
                break
            n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
            n_frame = draw_bounding_boxes(n_frame, obj_meta, obj_meta.confidence)
            # Convert to numpy array and encode
            frame_copy = np.array(n_frame, copy=True, order='C')
            frame_copy = cv2.cvtColor(frame_copy, cv2.COLOR_RGBA2BGRA)
            _, img_encoded = cv2.imencode('.jpg', frame_copy)
            base64_encoded_image = base64.b64encode(img_encoded).decode('utf-8')
            if platform_info.is_integrated_gpu():
               pyds.unmap_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
            obj_data = {
                "frame_number": frame_number,
                "class_id": obj_meta.class_id,
                "object_id": obj_meta.object_id,
                "confidence": obj_meta.confidence,
                "bbox": {
                    "left": obj_meta.rect_params.left,
                    "top": obj_meta.rect_params.top,
                    "width": obj_meta.rect_params.width,
                    "height": obj_meta.rect_params.height
                "image": base64_encoded_image
            publish_mqtt_message(obj_data)
            try:
                obj_meta_list = obj_meta_list.next
                break
        try:
            l_frame = l_frame.next
            break
    return Gst.PadProbeReturn.OK
When I deleted the code between #s and “image” in the data, the app can send message by mqtt and stream the rtsp properly. I guess there’s something wrong with the code there but I don’t know what it is.
Full code
import sys
import base64
import cv2
import numpy as np
sys.path.append("../")
from common.bus_call import bus_call
from common.platform_info import PlatformInfo
import pyds
import platform
import math
import time
from ctypes import *
import gi
gi.require_version("Gst", "1.0")
gi.require_version("GstRtspServer", "1.0")
from gi.repository import Gst, GstRtspServer, GLib
import configparser
import datetime
import paho.mqtt.client as mqtt
import json
import argparse
MAX_DISPLAY_LEN = 64
PGIE_CLASS_ID_PWH = 0
PGIE_CLASS_ID_PWV = 1
PGIE_CLASS_ID_PNH = 2
PGIE_CLASS_ID_PNV = 3
MUXER_OUTPUT_WIDTH = 1920
MUXER_OUTPUT_HEIGHT = 1080
MUXER_BATCH_TIMEOUT_USEC = 33000
TILED_OUTPUT_WIDTH = 1280
TILED_OUTPUT_HEIGHT = 720
GST_CAPS_FEATURES_NVMM = "memory:NVMM"
OSD_PROCESS_MODE = 0
OSD_DISPLAY_TEXT = 0
PGIE_CONFIG_FILE = "config_infer_primary.txt"
MSCONV_CONFIG_FILE = "msgconv_config.txt"
schema_type = 0
proto_lib = "/opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_mqtt_proto.so"
conn_str = "localhost;1883;deepstream/notify"
pgie_classes_str = ["pwh", "pwv", "pnh", "pnv"]
# MQTT configurations
MQTT_BROKER = "localhost"
MQTT_PORT = 1883
MQTT_TOPIC = "deepstream/notify"
def extract_frame_as_base64(gst_buffer, frame_meta):
    # Convert GstBuffer to numpy array
    frame_image = np.array(n_frame, copy=True, order='C')
    frame_image = cv2.cvtColor(frame_image, cv2.COLOR_RGBA2BGRA)
    # Encode image to base64
    _, buffer = cv2.imencode('.jpg', frame_image)
    frame_base64 = base64.b64encode(buffer).decode('utf-8')
    return frame_base64
    frame_number = 0
    num_rects = 0
    if not gst_buffer:
        return
        try:
            break
        if ts_from_rtsp:
        #frame_base64 = extract_frame_as_base64(gst_buffer, frame_meta)
            try:
                break
            obj_data = {
                "bbox": {
            try:
                break
        try:
            break
def draw_bounding_boxes(image, obj_meta, confidence):
    confidence = '{0:.2f}'.format(confidence)
    rect_params = obj_meta.rect_params
    top = int(rect_params.top)
    left = int(rect_params.left)
    width = int(rect_params.width)
    height = int(rect_params.height)
    obj_name = pgie_classes_str[obj_meta.class_id]
    # image = cv2.rectangle(image, (left, top), (left + width, top + height), (0, 0, 255, 0), 2, cv2.LINE_4)
    color = (0, 0, 255, 0)
    w_percents = int(width * 0.05) if width > 100 else int(width * 0.1)
    h_percents = int(height * 0.05) if height > 100 else int(height * 0.1)
    linetop_c1 = (left + w_percents, top)
    linetop_c2 = (left + width - w_percents, top)
    image = cv2.line(image, linetop_c1, linetop_c2, color, 6)
    linebot_c1 = (left + w_percents, top + height)
    linebot_c2 = (left + width - w_percents, top + height)
    image = cv2.line(image, linebot_c1, linebot_c2, color, 6)
    lineleft_c1 = (left, top + h_percents)
    lineleft_c2 = (left, top + height - h_percents)
    image = cv2.line(image, lineleft_c1, lineleft_c2, color, 6)
    lineright_c1 = (left + width, top + h_percents)
    lineright_c2 = (left + width, top + height - h_percents)
    image = cv2.line(image, lineright_c1, lineright_c2, color, 6)
    # Note that on some systems cv2.putText erroneously draws horizontal lines across the image
    image = cv2.putText(image, obj_name + ',C=' + str(confidence), (left - 10, top - 10), cv2.FONT_HERSHEY_SIMPLEX, 0.5,
                        (0, 0, 255, 0), 2)
    return image
def publish_mqtt_message(data):
    client = mqtt.Client()
    client.connect(MQTT_BROKER, MQTT_PORT, 60)
    client.publish(MQTT_TOPIC, json.dumps(data))
    client.disconnect()
def cb_newpad(decodebin, decoder_src_pad, data):
    print("In cb_newpad\n")
    caps = decoder_src_pad.get_current_caps()
    gststruct = caps.get_structure(0)
    gstname = gststruct.get_name()
    source_bin = data
    features = caps.get_features(0)
    print("gstname=", gstname)
    if gstname.find("video") != -1:
        print("features=", features)
        if features.contains("memory:NVMM"):
            bin_ghost_pad = source_bin.get_static_pad("src")
            if not bin_ghost_pad.set_target(decoder_src_pad):
                sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
        else:
            sys.stderr.write("Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy, Object, name, user_data):
    print("Decodebin child added:", name, "\n")
    if name.find("decodebin") != -1:
        Object.connect("child-added", decodebin_child_added, user_data)
    if ts_from_rtsp:
        if name.find("source") != -1:
            pyds.configure_source_for_ntp_sync(hash(Object))
def create_source_bin(index, uri):
    print("Creating source bin")
    bin_name = "source-bin-%02d" % index
    print(bin_name)
    nbin = Gst.Bin.new(bin_name)
    if not nbin:
        sys.stderr.write("Unable to create source bin \n")
    uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
    if not uri_decode_bin:
        sys.stderr.write("Unable to create uri decode bin \n")
    uri_decode_bin.set_property("uri", uri)
    uri_decode_bin.connect("pad-added", cb_newpad, nbin)
    uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
    Gst.Bin.add(nbin, uri_decode_bin)
    bin_pad = nbin.add_pad(Gst.GhostPad.new_no_target("src", Gst.PadDirection.SRC))
    if not bin_pad:
        sys.stderr.write("Failed to add ghost pad in source bin \n")
        return None
    return nbin
def main(args):
    number_sources = len(args)
    global platform_info
    platform_info = PlatformInfo()
    Gst.init(None)
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    is_live = False
    if not pipeline:
        sys.stderr.write("Unable to create Pipeline \n")
    print("Creating streamux \n ")
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write("Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        print("Creating source_bin ", i, " \n ")
        uri_name = args[i]
        if uri_name.find("rtsp://") == 0:
            is_live = True
        source_bin = create_source_bin(i, uri_name)
        if not source_bin:
        pipeline.add(source_bin)
        padname = "sink_%u" % i
        sinkpad = streammux.request_pad_simple(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad = source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    print("Creating Pgie \n ")
    if gie == "nvinfer":
        pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    else:
        pgie = Gst.ElementFactory.make("nvinferserver", "primary-inference")
    if not pgie:
        sys.stderr.write("Unable to create pgie \n")
    print("Creating tiler \n ")
    tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    if not tiler:
        sys.stderr.write("Unable to create tiler \n")
    print("Creating nvvidconv \n ")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write("Unable to create nvvidconv \n")
    print("Creating nvosd \n ")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write("Unable to create nvosd \n")
    nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd")
    if not nvvidconv_postosd:
        sys.stderr.write("Unable to create nvvidconv_postosd \n")
    caps = Gst.ElementFactory.make("capsfilter", "filter")
    caps.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420"))
    if codec == "H264":
        encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
        print("Creating H264 Encoder")
    elif codec == "H265":
        encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
        print("Creating H265 Encoder")
    if not encoder:
        sys.stderr.write("Unable to create encoder")
    encoder.set_property("bitrate", bitrate)
        encoder.set_property("preset-level", 1)
        encoder.set_property("insert-sps-pps", 1)
    if codec == "H264":
        rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
        print("Creating H264 rtppay")
        rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
        print("Creating H265 rtppay")
    if not rtppay:
        sys.stderr.write("Unable to create rtppay")
    updsink_port_num = 5400
    sink = Gst.ElementFactory.make("udpsink", "udpsink")
    if not sink:
        sys.stderr.write("Unable to create udpsink")
    sink.set_property("host", "224.224.255.255")
    sink.set_property("port", updsink_port_num)
    sink.set_property("async", False)
    sink.set_property("sync", 1)
    streammux.set_property("width", MUXER_OUTPUT_WIDTH)
    streammux.set_property("height", MUXER_OUTPUT_HEIGHT)
    streammux.set_property("batch-size", number_sources)
    streammux.set_property("batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC)
    pgie.set_property('config-file-path', PGIE_CONFIG_FILE)
    if ts_from_rtsp:
        streammux.set_property("attach-sys-ts", 0)
    if gie=="nvinfer":
        pgie.set_property("config-file-path", PGIE_CONFIG_FILE)
    else:
        pgie.set_property("config-file-path", "dstest1_pgie_inferserver_config.txt")
    print("Adding elements to Pipeline \n")
    pipeline.add(pgie)
    pipeline.add(tiler)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    pipeline.add(nvvidconv_postosd)
    pipeline.add(caps)
    pipeline.add(encoder)
    pipeline.add(rtppay)
    pipeline.add(sink)
    streammux.link(pgie)
    pgie.link(tiler)
    tiler.link(nvvidconv)
    nvvidconv.link(nvosd)
    nvosd.link(nvvidconv_postosd)
    nvvidconv_postosd.link(caps)
    caps.link(encoder)
    encoder.link(rtppay)
    rtppay.link(sink)
    print("Linking elements in the Pipeline \n")
    tiler.set_property("rows", int(math.sqrt(number_sources)))
    tiler.set_property("columns", int(math.ceil((1.0 * number_sources) / tiler.get_property("rows"))))
    tiler.set_property("width", TILED_OUTPUT_WIDTH)
    tiler.set_property("height", TILED_OUTPUT_HEIGHT)
    pgie_batch_size = pgie.get_property("batch-size")
    if pgie_batch_size != number_sources:
        print("WARNING: Overriding infer-config batch-size", pgie_batch_size, " with number of sources ", number_sources, " \n")
        pgie.set_property("batch-size", number_sources)
    print("Creating RTSP Streaming Server \n")
    server = GstRtspServer.RTSPServer.new()
    server.props.service = "%d" % RTSP_PORT
    server.attach(None)
    factory = GstRtspServer.RTSPMediaFactory.new()
    factory.set_launch("( udpsrc name=pay0 port=%d caps=\"application/x-rtp, media=video, clock-rate=90000, encoding-name=H264, payload=96 \" )" % updsink_port_num)
    factory.set_shared(True)
    server.get_mount_points().add_factory(MOUNT_POINT, factory)
    print("\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d%s ***\n\n" % (RTSP_PORT, MOUNT_POINT))
    print("Starting pipeline \n")
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", bus_call, loop)
    pgie_src_pad = pgie.get_static_pad("src")
    if not pgie_src_pad:
        sys.stderr.write("Unable to get src pad\n")
    else:
        pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, pgie_src_pad_buffer_probe, 0)
    if is_live:
        print("Atleast one of the sources is live")
        streammux.set_property("live-source", 1)
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    print("Exiting app\n")
    pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
    parser = argparse.ArgumentParser()
    parser.add_argument("input_uri", nargs='+', help="URI of the input streams")
    parser.add_argument("--gie", default="nvinfer", choices=["nvinfer", "nvinferserver"], help="Type of GIE (default: nvinfer)")
    parser.add_argument("--codec", default="H264", choices=["H264", "H265"], help="Codec type (default: H264)")
    parser.add_argument("--bitrate", type=int, default=4000000, help="Bitrate of encoding (default: 4000000)")
    parser.add_argument("--rtsp-port", type=int, default=8554, help="Port for RTSP (default: 8554)")
    parser.add_argument("--mount-point", default="/ds-test", help="Mount point for RTSP (default: /ds-test)")
    parser.add_argument("--ts-from-rtsp", action='store_true', help="Extract NTP timestamps from RTSP")
    args = parser.parse_args()
    global gie
    global codec
    global bitrate
    global RTSP_PORT
    global MOUNT_POINT
    global ts_from_rtsp
    gie = args.gie
    codec = args.codec
    bitrate = args.bitrate
    RTSP_PORT = args.rtsp_port
    MOUNT_POINT = args.mount_point
    ts_from_rtsp = args.ts_from_rtsp
    main(args.input_uri)
do you mean you are using player to play the output rtsp and the player stopped rendering?
seems you are using the third-party lib. please add some logs in publish_mqtt_message to check if the the app hung in this function. we also suggest using the ready-made sending broker solution. please refer to deepstream_test_4.py.
Yes, the stream stops when I use player to watch it. The app can work when I send the message of detected object. However it can’t work properly when I try to send image data in the message.
  1. using third-party lib to sending broker would be outside of DeepStream. you can add log in publish_mqtt_message to check if the the app hung and the return value of client.publish is correct.
  2. C++ demo /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test4/ already supports sending image to broker. please refer to “3.Send the image by the broker” in the readme. then port the logics.
I refered to deepstream_imagedata-multistream.py and fixed my code and I encountered an error
I tried to apply tiler_sink_pad_buffer_probe and added related code.
Here’s the full code of tiler_sink_pad_buffer_probe
def tiler_sink_pad_buffer_probe(pad, info, u_data):
    frame_number = 0
    num_rects = 0
    if not gst_buffer:
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
            break
        l_obj = frame_meta.obj_meta_list
        num_rects = frame_meta.num_obj_meta
        is_first_obj = True
        save_image = False
        obj_counter = {
            PGIE_CLASS_ID_PEOPLE_WITH_HELMET: 0,
            PGIE_CLASS_ID_PEOPLE_WITH_VEST: 0,
            PGIE_CLASS_ID_PEOPLE_NO_HELMET: 0,
            PGIE_CLASS_ID_PEOPLE_NO_VEST: 0
        while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            obj_counter[obj_meta.class_id] += 1
            # Periodically check for objects with borderline confidence value that may be false positive detections.
            # If such detections are found, annotate the frame with bboxes and confidence value.
            # Save the annotated frame to file.
            if saved_count["stream_{}".format(frame_meta.pad_index)] % 30 == 0 and (
                    MIN_CONFIDENCE < obj_meta.confidence < MAX_CONFIDENCE):
                if is_first_obj:
                    is_first_obj = False
                    # Getting Image data using nvbufsurface
                    # the input should be address of buffer and batch_id
                    # convert python array into numpy array format in the copy mode.
                    # convert the array into cv2 default color format
                        # If Jetson, since the buffer is mapped to CPU for retrieval, it must also be unmapped
                        pyds.unmap_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id) # The unmap call should be made after operations with the original array are complete.
        #  The original array cannot be accessed after this call.
                save_image = True
            try:
                l_obj = l_obj.next
                break
        print("Frame Number=", frame_number, "Number of Objects=", num_rects, "pnh_count=",
              obj_counter[PGIE_CLASS_ID_PEOPLE_NO_HELMET], "pnv_count=", obj_counter[PGIE_CLASS_ID_PEOPLE_NO_VEST])
        # update frame rate through this probe
        stream_index = "stream{0}".format(frame_meta.pad_index)
        global perf_data
        perf_data.update_fps(stream_index)
        if save_image:
            img_path = "{}/stream_{}/frame_{}.jpg".format("frames", frame_meta.pad_index, frame_number)
            cv2.imwrite(img_path, frame_copy)
        saved_count["stream_{}".format(frame_meta.pad_index)] += 1
        try:
            break
How can I fix the error?
did you define the global variable saved_count? using unmodified deepstream_imagedata-multistream.py, can you reproduce the “KeyError: 'stream_0”? if no, please compare the unmodified code with your custom code to narrow down this issue.
Yes, I defined saved_count.
I tried unmodified deepstream_imagedata-multistream.py and encountered another error
And I also tried gst-launch-1.0 videotestsrc ! nv3dsink command and it shows
for a workaround, you can use fakesink instead. Is this still an DeepStream issue to support? Thanks!
Problem solved. Thanks for your help!
