Multiple Bounding Boxes for the Same Detection
• Hardware Platform (Jetson / GPU) : Jetson
• DeepStream Version : DeepStream 6
• JetPack Version (valid for Jetson only) : Jetpack 4.6 (32.6.1)
• TensorRT Version : 8.0.6.1
• Issue Type( questions, new requirements, bugs) : Question
Hello Everyone, when I am performing inference on the video stream I get multiple bounding boxes for the same detection !!
However, this behavior started after using a different model file which was trained on a comparatively large number of images as compared to the previous model file !!
For the previous model file, the inference configuration was used as follows !!
[property]
gpu-id=0
gie-unique-id=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
network-type=0
process-mode=1
#force-implicit-batch-dim=1
#batch-size=1
model-color-format=0
#maintain-aspect-ratio=1
net-scale-factor=0.0039215697906911373
## 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
cluster-mode=3
infer-dims=3;544;960
uff-input-blob-name=input_1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
num-detected-classes=3
interval=3
enable-dla=0
use-dla-core=0
[class-attrs-all]
group-threshold=1
pre-cluster-threshold=0.23
#post-cluster-threshold=0.1
#nms-iou-threshold=0.2
nms-iou-threshold=0.6
minBoxes=3
dbscan-min-score=1.1
eps=0.1
detected-min-w=20
detected-min-h=20
I would like to know which parameters can be tweaked so that I can get only one bounding box per detection for the new model file!!
The spec file used for training the new model file with a large number of images is as follows:
random_seed: 42
dataset_config {
  data_sources {
    tfrecords_path: "/workspace/tao-experiments/data/tfrecords/kitti_trainval/*"
    image_directory_path: "/workspace/tao-experiments/data/training_coco"
  image_extension: "jpg"
  target_class_mapping {
    key: "person"
    value: "person"
    key: "face"
    value: "face"
    key: "bag"
    value: "bag"
  validation_fold: 0
augmentation_config {
  preprocessing {
    output_image_width: 960
    output_image_height: 544
    crop_right: 960
    crop_bottom: 544
    min_bbox_width: 1.0
    min_bbox_height: 1.0
    output_image_channel: 3
  spatial_augmentation {
    hflip_probability: 0.5
    zoom_min: 1.0
    zoom_max: 1.0
    translate_max_x: 8.0
    translate_max_y: 8.0
    rotate_rad_max: 0.174
  color_augmentation {
    color_shift_stddev: 0.0
    hue_rotation_max: 25.0
    saturation_shift_max: 0.20000000298
    contrast_scale_max: 0.10000000149
    contrast_center: 0.5
postprocessing_config {
  target_class_config {
    key: "person"
    value {
      clustering_config {
        coverage_threshold: 0.00499999988824
        dbscan_eps: 0.20
        dbscan_min_samples: 0.0500000007451
        minimum_bounding_box_height: 20
    key: "bag"
    value {
      clustering_config {
        dbscan_eps: 0.15000000596
    key: "face"
    value {
      clustering_config {
        coverage_threshold: 0.005
        dbscan_eps: 0.15
model_config {
  pretrained_model_file: "/workspace/tao-experiments/detectnet_v2/tlt_peoplenet_vunpruned_v2.1/resnet34_peoplenet.tlt"
  arch: "resnet"
  num_layers: 34
  load_graph: true
  all_projections: true
  # use_pooling: false
  use_batch_norm: true
  # freeze_bn = true
   freeze_blocks: 0
   freeze_blocks: 1
   freeze_blocks: 2
   freeze_blocks: 3
   freeze_blocks: 4
  objective_set {
    bbox {
      scale: 35.0
      offset: 0.5
    cov {
  training_precision {
    backend_floatx: FLOAT32
evaluation_config {
  validation_period_during_training: 10
  first_validation_epoch: 1
  minimum_detection_ground_truth_overlap {
    key: "person"
    value: 0.5
    key: "bag"
    value: 0.5
    key: "face"
    value: 0.5
  evaluation_box_config {
    key: "person"
    value {
      minimum_height: 20
      maximum_height: 9999
      minimum_width: 10
      maximum_width: 9999
    key: "bag"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
    key: "face"
    value {
      minimum_height: 20
      minimum_width: 10
      maximum_width: 9999
  average_precision_mode: INTEGRATE
cost_function_config {
  target_classes {
    class_weight: 10.0
    coverage_foreground_weight: 0.0500000007451
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      initial_weight: 10.0
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  target_classes {
    class_weight: 1.0
    objectives {
      initial_weight: 1.0
      weight_target: 1.0
    objectives {
      weight_target: 10.0
  enable_autoweighting: true
  max_objective_weight: 0.999899983406
  min_objective_weight: 9.99999974738e-05
training_config {
  batch_size_per_gpu: 32
  num_epochs: 120
  learning_rate {
    soft_start_annealing_schedule {
      min_learning_rate: 2e-07
      max_learning_rate: 5e-04
      soft_start: 0.1
      annealing: 0.699999988079
  regularizer {
    type: L1
    weight: 3.00000002618e-09
  optimizer {
    adam {
      epsilon: 9.99999993923e-09
      beta1: 0.899999976158
      beta2: 0.999000012875
  cost_scaling {
    initial_exponent: 20.0
    increment: 0.005
    decrement: 1.0
  checkpoint_interval: 5
bbox_rasterizer_config {
    key: "person"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
      bbox_min_radius: 1.0
    key: "bag"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
    key: "face"
    value {
      cov_center_x: 0.5
      cov_center_y: 0.5
      cov_radius_x: 1.0
      cov_radius_y: 1.0
  deadzone_radius: 0.400000154972
Looking forward to your responses !!
This very likely seems related to cluster-mode and the parameters set for the respective mode.
You’re currently using DBSCAN + NMS. Maybe try them both individually first and see.
So for example change cluster-mode to 1 for DBSCAN and run your inference. You may tune pre-cluster-threshold, minBoxes, dbscan-min-score and eps values for that mode.
For second experiment, you can try the NMS mode which is cluster-mode=2 and try to tweak pre-cluster-threshold and nms-iou-threshold
Hii @marmikshah,
Thanks for your earliest reply ! For the previous model, I used the cluster mode as 3 but now for the new model I am using cluster mode as 1. Do you have an idea of what could be a good starting point for all these parameters?
Also, I would like since, in TAO training, the cluster mode used is DBSCAN, will using only NMS have an effect on that?
These parameters are quite subjective and have no perfect value for a model. You can do some trial and error starting from the example values provided by NVIDIA in the nvinfer’s document here Gst-nvinfer — DeepStream 6.1.1 Release documentation
Listed out their example values from the document above.
dbscan-min-score=0.7
eps=0.2
pre-cluster-threshold=0.5
For your second question, yes if you use NMS for clustering here, it will still work. Just need to tune these parameters by increasing or decreasing them. Clustering in general should simply group all similar bboxes for an object and return 1 box. So both NMS and DBSCAN should work.
Sometimes even printing your detector’s confidence can be helpful to eliminate some boxes having very low confidence. You can add a probe at the sink pad at GstElement after your nvinfer and filter out bboxes using their confidence.
Hey Marmik,
Thanks for your reply. I tried the NMS clustering mode which made the detections worse as it generated more false positives. What worked for me was using the DBSCAN clustering mode and a higher eps value which eliminated multiple bounding boxes !!
