I’ve been successfully testing the jetson-inference DetectNet c++ application (./detectnet) with a rtp streaming camera.
Also managed to write my own version based on the my-recognition example. How can I add support for more than one camera? And would this require multiple instances of the detection network or can I feed the images through the same instance?
Also what is the difference between jetson-inference and using DeepStream SDK or other alternatives?
For multiple RTSP sources, it might be easier to use DeepStream SDK. You can modify config file and run deepstream-app. Please check the latest release:
You can create additional jetson-inference videoSource objects that use different cameras. However, the command-line parsing is setup for one camera. So you may wish to use this videoSource::Create() constructor where you manually pass in the video options and camera URIs:
