Multiple Reduction in a 2D array Using the easiest reduction example of the SDK
Hello everyone,
I continue my discovery about reduction !
Now, I want to do something little special !
I have an array of floats of 4 rows and 8 columns, I want to have , after reduction, an array of 1 row & 8 columns which will contain the sum of every column. For example
0   1	2	3	4	5	6	7
8   9	10   11   12   13   14   15
16  17   18   19   20   21   22   23
24  25   26   27   28   29   30   31
gives
48  52  56   60   64   68   72   76
So I declare 8 blocks that will contain 4 threads each, and I make a normal reduction for every block !
The code I execute on the device is the same than the Reduction #1 example :
// Kernel that executes on the CUDA device
__global__ void reduction(float *g_idata, float *g_odata) {
	extern __shared__ int sdata[];
	// each thread loads one element from global to shared mem
	unsigned int tid = threadIdx.x;
	unsigned int i = blockIdx.x*blockDim.x + threadIdx.x;
	sdata[tid] = g_idata[i];
	__syncthreads();
	// do reduction in shared mem
	for (unsigned int s=1; s < blockDim.x; s *= 2)  {
		if ( tid % (2*s)==0)
			sdata[tid] += sdata[tid + s];
		__syncthreads();
	// write result for this block to global mem
	if (tid == 0) g_odata[blockIdx.x] = sdata[0];
Doing so the block 0 which will compute the 1st column will write its result in g_odata[0], the block 1 will compute the 2nd column and write in g_odata[1] and so on and so on !
Unfortunately it does not work and after lots of memory schematics I’ve made, I think the problem is not on the device code ! (Please correct me if I’m wrong)
So my main code is :
float * d_result;
float * d_result1;
unsigned int W = 8;
unsigned int H = 4;
float h_result[W][H];
float h_result1[W][H];
size_t pitch,pitch1;
int temp=0;
int i=0,j=0;
// Matrix filling
  for (i=0;i<W;i++)
	  for(j=0;j<H;j++)
	  h_result[i][j]=temp;
	  temp++;
// Memory allocation
   cudaMallocPitch((void**) &d_result, &pitch, W*sizeof(float), H);
   cudaMallocPitch((void**) &d_result1, &pitch1, W*sizeof(float), H);
// Memory copying
   cudaMemcpy2D(d_result,pitch,h_result,W*sizeof(float),W*sizeof(float),H,cudaMemcpyHostToDevice);
	dim3 threadPerBlock(H,1);
	dim3 dimGrid(W,1);
	reduction<<<dimGrid,threadPerBlock, H*sizeof(float)>>>(d_result,d_result1);
	cudaMemcpy2D(h_result1,W*sizeof(float),d_result1,pitch1,W*sizeof(float),H,cudaMemcpyDeviceToHost);
	for(j=0;j<H;j++) for(i=1;i<W;i++) h_result[0][j]+=h_result[i][j];
	cout << "Expected : " << endl;
	for(j=0;j<H;j++) cout << h_result[0][j] << " ";
	cout << endl << "Obtained : " << endl;
	for(i=0;i<H;i++) cout << h_result1[0][i] << " ";
	cout << endl;
cudaFree(d_result);
cudaFree(d_result);
  return 0;
Could you see any problem in my configuration or in my way of dealing about memory copying or allocation ?!
No idea ?
    __syncthreads();
I have had problems in the past when performing the if statement that you have, due to problems with performing mod. Please try one of the other methods sugested by nVidia to avoid using mod.
If you have any success, please write back! David
I have tried your suggestion but nothing’s better !
Do we agree that the size of the shared memory I’m sending to the kernell is the size of the shared memory PER block ?
I will try to understand what is going on with this code and every suggestion is welcomed !
Hello again !
The source of my problem was that my CudaMallocPitch did not give me a continuous space memory (I don’t understand why) so I decided to linearize my h_Result[W][H] array to a h_in[WH] array in order to use CudaMalloc & CudaMemCpy instead of CudaMallocPitch & CudaMemCpy2D !
That’s working ! So, for those who are interested, is here a multiple reduction that works :
int main()
float * d_out;
float * d_in;
unsigned int W = 256;
unsigned int H = 24;
float h_in[W*H];
float h_out[W];
int index=0;
int i=0,j=0,k=0;
for (i=0;i<W;i++)
	  for(j=0;j<H;j++)
		  h_in[index]=j+1;
		  index++;
	cudaMalloc((void**)&d_in,W*H*sizeof(float));
	cudaMalloc((void**)&d_out,W*sizeof(float));
	// Memory copying
	cudaMemcpy(d_in,h_in,W*H*sizeof(float),cudaMemcpyHostToDevice);
	dim3 dimGrid(W,1);
	reduction<<<dimGrid,threadPerBlock, H*sizeof(float)>>>(d_in,d_out,k);
	cudaMemcpy(h_out,d_out,W*sizeof(float),cudaMemcpyDeviceToHost);
	for (i=0;i<W;i++) cout << h_out[i] << " ";
	cout << endl;
cudaFree(d_in);
cudaFree(d_out);
  return 0;
Maybe some of you can understand why my 2D progam was not working, even if it will not be useful for my program, I would be really interested to understand what was wrong there !
I suspect that the cudaMallocPitch documentation constains the answer. That function can and will pad allocated storage for improved performance.
I think that you need to use column-major for h_result.
I modify your code in the first post,
(1) use column-major for h_result
(2) use cudaMalloc and cudaMemcpy
it works. However I am confused at this post, do you use column-major or row-major
