Reduction & block dimension Using the easiest reduction example of the SDK
Hello everyone !
I need to do a reduction for my program !
So I’ve read the doc of Nvidia about it (good paper btw) and now, I’m trying to do the same !
And obviously, it does not work !
I’m doing exactly the same thing than the first example of the SDK so I assume my mistake is about the ThreadPerBlock and/or the DimGrid I’ve choosen !
I’ve tried with lots of different values but the result is the same !
Here is my code :
// Kernel that executes on the CUDA device
__global__ void reduction(float *result_in,float*result_out)
  extern __shared__ float sdata[];
unsigned int s=1;
unsigned int tid = threadIdx.x;
  unsigned int i = blockIdx.x*blockDim.x + threadIdx.x;
  sdata[tid] = result_in[i];
  __syncthreads();
for(s=1; s<blockDim.x;s *=2)
	  if (tid % (2*s) == 0)
		  sdata[tid] += sdata[tid+s];
	__syncthreads();
if(tid==0) result_out[blockIdx.x] = sdata[0];
int main()
float * d_result;
float * d_result1;
int W = 16;
float h_result[W];
float h_result1[W];
int i=0;
for (i=0;i<W;i++) h_result[i]=i;
	cudaMalloc((void**)&d_result,W*sizeof(float));
	cudaMalloc((void**)&d_result1,W*sizeof(float));
	cudaMemcpy(d_result,h_result,W*sizeof(float),cudaMemcpyHostToDevice);
dim3 threadPerBlock(16,2);
  dim3 dimGrid(W/threadPerBlock.x , 1);
	reduction<<<dimGrid,threadPerBlock>>>(d_result,d_result1);
	cudaMemcpy(h_result1,d_result1,W*sizeof(float),cudaMemcpyDeviceToHost);
	int res=0;
 	for(int k=0;k<W; k++) res+= h_result[k];
	cout << "Res : " << res << endl;
	cout << "Res2 : " << h_result1[0] << endl;
cudaFree(d_result);
cudaFree(d_result1);
  return 0;
I’ve chosen a power of two so it should work ! and I get 28 instead of 120. Can somebody explains me which newby mistake I am doing ?
For information :
according to your kernel
I suppose that you want to use 1-D thread block and 1-D grid, then
your execution configuration is wrong.
modify
as
dim3 threadPerBlock(16,1);
second, you use dynamic shared memory in your kernel
however you don’t specify how many bytes you need in execution configuration.
modify
as
reduction<<<dimGrid,threadPerBlock, 16*sizeof(float) >>>(d_result,d_result1);
Ok ! Thank you very much !
I was using a ThreadPerBlock = (16,1) I just made a mistake when I recopied the line !
But obviously you’re right my problem was that I did’nt specify how bytes of shared memory I needed !
I also need to do reduction, especially, mean of array elements. I checked example of reduction in SDK, but it seems hard to understand. But I also used cascade sum. This code work correctly in emulation mode, but on GPU it doesn’t work. It has errors in results ( big numbers, NANs or else incorrect means) and sometimes lead to artefacts on my monitor (moving snowflakes) like I broke some GPU memory while running the code. Who can tell me, where is the problem.
__global__ void __meanStage1(float *A, float *Sum, long N, long M)
	long iS = blockIdx.y * gridDim.x + blockIdx.x;
	for (long j= blockIdx.y * BLOCK_SIZE; j< (blockIdx.y+1) * BLOCK_SIZE; j++)
	   		for (long i= blockIdx.x * BLOCK_SIZE; i< (blockIdx.x+1) * BLOCK_SIZE; i++)
			if( i < N && j < M)
			Sum[iS] = Sum[iS] + A[j * M + i];
	__syncthreads();
__global__ void __meanStage2(float *a,float *mean, float *sum, long dX, long dY, long N, long M)
	*mean = 0;
	for (long i=0;i<dX * dY;i++)
		*mean = *mean + sum[i];
	if (M*N!=0)
	*mean = (*mean)/(N*M);
	__syncthreads();
void means(float *a,float &Means, long N, long M)
	float *sum,*mean;
	long iS,jS;
	iS = N / BLOCK_SIZE;
	jS = M / BLOCK_SIZE;
	cudaMalloc((void**) &mean , sizeof(float));
	cudaMalloc((void**) &sum , iS * jS * sizeof(float));
	cudaMemset(sum,0, iS * jS * sizeof(float));
	dim3 dimBlock1(1, 1);
	dim3 dimGrid1(N/BLOCK_SIZE, M/BLOCK_SIZE);
	__meanStage1<<<dimGrid1, dimBlock1>>>(a, sum, N, M);
	dim3 dimBlock2(1, 1);
	dim3 dimGrid2(1, 1);
	__meanStage2<<<dimGrid2, dimBlock2>>>(a, mean, sum, iS, jS, N, M);
	cudaFree(sum);
	cudaMemcpy(&Means, mean, sizeof(float),cudaMemcpyDeviceToHost);
	cudaFree(mean);
The indexing scheme in __meanStage1() looks completely wrong. Every thread in any block will have the same iS value, which will cause a memory race - every thread is simultaneously trying to write to the same entry in Sum. I am not surprised the results are rubbish.
yes, but I make only one thread in each block, and N/16 X M/16 blocks in grid.
and thought that this
formula will set different iS for each block (absolute address of block in grid) where I have only one thread.
now I found presentation of fast reduce by Mark Harris and got 4-th method from there, but in gpu mode it does segmentation fault.
__global__ void reduce(float *g_idata,float *g_odata)
	extern __shared__ int sdata[];
	unsigned int i = blockIdx.x*(blockDim.x*2) + threadIdx.x;
	sdata[tid] = g_idata[i] + g_idata[i+blockDim.x];
	__syncthreads();
	for (unsigned int s=blockDim.x/2; s>0; s>>=1) {
	if (tid < s) {
	sdata[tid] += sdata[tid + s];
	__syncthreads();
	if (tid == 0) g_odata[blockIdx.x] = sdata[0];
//float *a - input matrix in GPU memory,
//float Means - mean from host memory
void meanh(float *a,float &Means, long N, long M)
	float *sum;
	cudaMalloc((void**) &sum , N * M * sizeof(float));
	cudaMemcpy(sum, a, N*M*sizeof(float),cudaMemcpyDeviceToDevice);
	dim3 dimBlock(BLOCK_SIZE, BLOCK_SIZE);
	dim3 dimGrid(N/BLOCK_SIZE, M/BLOCK_SIZE);
	reduce<<<dimGrid, dimBlock>>>(sum,sum);
	cudaMemcpy(&Means, sum, sizeof(float),cudaMemcpyDeviceToHost);
	cudaFree(sum);
	Means = Means / (N*M);
