• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
In Deepstream 6.2 while using MultiUriSrcBin plugin, is there a way to carry sensorId (camera name) we provide while adding a camera into frame meta.
Right now frame meta contains source_id equivalent to streammux pad index. I would like to obtain sensorId along with source_id in frame meta, how can I achieve this?
Where exactly does source_id get added to frame meta?
you can use nvds_add_user_meta_to_frame to add user information to frame. please refer to sample /opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-user-metadata-test
pleaase refer tonvmultiurisrcbin, sensor-id-list vector is one to one mapped with the uri-list.
please refer to sample opt\nvidia\deepstream\deepstream-6.2\sources\apps\sample_apps\deepstream-test5\configs\test5_config_file_nvmultiurisrcbin_src_list_attr_all.txt
