GPU • DeepStream Version
7.1 • JetPack Version (valid for Jetson only) • TensorRT Version
10.3 • NVIDIA GPU Driver Version (valid for GPU only)
566.03 • Issue Type( questions, new requirements, bugs)
new requirements • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Description:
When using Gst-nvmultiurisrcbin with nvds_rest_server, there’s an inconsistency in the handling of camera_url between different endpoints.
Current Behavior:
For /stream/add endpoint:
Successfully adds sensors with camera_url
Documentation correctly states mandatory fields (value/camera_id, value/camera_url, value/change)
For /stream/remove endpoint:
Requires camera_url as mandatory field
Expected Behavior:
The /api/v1/stream/get-stream-info endpoint should include camera_url in its response, since:
camera_url is a mandatory field for other endpoints
camera_url is required for stream removal
This would provide consistency across all stream management endpoints
Issue Impact:
Currently, to remove a stream, users must maintain camera_url information separately since it’s not available through the get-stream-info endpoint, despite being required for removal.
Code Analysis:
Reviewed nvds_rest_server implementation
Found get_request_cb callback mechanism but unable to locate its implementation
Value exists in NvDsServerStreamInfo structure (value_camera_url) but isn’t being included in response
Request:
Please enhance the /api/v1/stream/get-stream-info endpoint to include camera_url in its response payload, maintaining consistency with other stream management endpoints.
The gst-nvmultiurisrcbin plugin is open source. You may add the uri to stream info REST API by modifying s_get_request_api_impl() function in /opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvmultiurisrcbin/gstdsnvmultiurisrcbin.cpp.
I need to implement runtime configuration changes for the nvdsanalytics plugin settings, following the approach discussed in this thread. However, I’ve encountered a limitation in the current API endpoint.
Current Situation
The /api/v1/stream/get-stream-info endpoint currently returns only basic camera information:
Implementing runtime configuration changes for nvdsanalytics
Properly identifying and updating specific stream components
Maintaining consistency between stream configurations and their respective IDs
Could you please help me add the stream_id field to the endpoint response? This would greatly help in implementing dynamic configuration updates for the analytics components.
It’s quite interesting to consider this information (camera_url, source_id) as default in the endpoint.
Added
if (sensor_info->source_id)
stream["source_id"] = std::to_string(sensor_info->source_id);
else
stream["source_id"] = std::string("");
An important point is to create an endpoint for nvdsanalytics now that we’ve already resolved the automatic reload of ROIs in the post mentioned above.
The source id is in the GstDsNvUriSrcConfig, it can be got by the camera_id and camera url with gst_nvmultiurisrcbincreator_get_source_config() interface. Please refer to s_stream_api_impl() source code.
