2060
• DeepStream Version
deepstream 7.0
• TensorRT Version
with deepstream 7.0 docker image
535
questions
How to use Gst-nvmultiurisrcbin to replace the source in the deepstream-app example?
The deepstream-app code is very good and very flexible, and can meet almost all my needs, except that there is no control to dynamically add and delete sources. Therefore, I want to use Gst-nvmultiurisrcbin to replace its source bin. I think the add_delete_source code in the example needs manual control, while nvmultiurisrcbin supports almost everything in source control.
How should I modify the deepstream-app example?
fanzh
July 25, 2024, 9:59am
3
On DS7.0, deepstream-test5, which is based on deepstream-app, already supports using nvmultiurisrcbin, please refer to \opt\nvidia\deepstream\deepstream-7.0\sources\apps\sample_apps\deepstream-test5\configs\test5_config_file_nvmultiurisrcbin_src_list_attr_all.txt
@fanzh
so,I tested test5 but didn’t see any place to use restful, did I do something wrong?
My test results are as follows:
./deepstream-test5-app -c configs/test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.yml
0:00:08.111230077 29623 0x5e378d3979e0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2095> [UID = 5]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.0/samples/models/Secondary_VehicleMake/resnet18_vehiclemakenet.etlt_b16_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:612 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
0:00:08.283396402 29623 0x5e378d3979e0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2198> [UID = 5]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.0/samples/models/Secondary_VehicleMake/resnet18_vehiclemakenet.etlt_b16_gpu0_int8.engine
0:00:08.289872059 29623 0x5e378d3979e0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<secondary_gie_1> [UID 5]: Load new model:/opt/nvidia/deepstream/deepstream-7.0/samples/configs/deepstream-app/config_infer_secondary_vehiclemake.yml sucessfully
0:00:17.360889886 29623 0x5e378d3979e0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2095> [UID = 4]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.0/samples/models/Secondary_VehicleTypes/resnet18_vehicletypenet.etlt_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
0:00:17.619269989 29623 0x5e378d3979e0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2198> [UID = 4]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.0/samples/models/Secondary_VehicleTypes/resnet18_vehicletypenet.etlt_b16_gpu0_int8.engine
0:00:17.620855667 29623 0x5e378d3979e0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<secondary_gie_0> [UID 4]: Load new model:/opt/nvidia/deepstream/deepstream-7.0/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.yml sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-7.0/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
0:00:27.604527387 29623 0x5e378d3979e0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2095> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.0/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b2_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:612 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x544x960
1 OUTPUT kFLOAT output_bbox/BiasAdd 16x34x60
2 OUTPUT kFLOAT output_cov/Sigmoid 4x34x60
0:00:27.850416036 29623 0x5e378d3979e0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2198> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.0/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b2_gpu0_int8.engine
0:00:27.853183732 29623 0x5e378d3979e0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-7.0/samples/configs/deepstream-app/config_infer_primary.yml sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
Active sources : 0
**PERF: FPS 0 (Avg) FPS 1 (Avg)
Thu Jul 25 10:34:11 2024
**PERF: 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:291>: Pipeline ready
** INFO: <bus_callback:277>: Pipeline running
fanzh
July 26, 2024, 3:04am
5
please use test5_config_file_nvmultiurisrcbin_src_list_attr_all.txt, which include “http-ip=localhost
http-port=9000” in [source-list].
@fanzh
The restful server does work, but there is a bug in test5. When I add a new stream to it, clicking the corresponding position of the playback window is invalid (it should switch to full screen). However, clicking the position of the original two streams can switch to full screen normally.
curl -XPOST 'http://localhost:7000/api/v1/stream/add' -d '{
"key": "sensor",
"value": {
"camera_id": "uniqueSensorID2",
"camera_name": "front_door",
"camera_url": "file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4",
"change": "camera_add",
"metadata": {
"resolution": "1920 x1080",
"codec": "h264",
"framerate": 30
"headers": {
"source": "vst",
"created_at": "2021-06-01T14:34:13.417Z"
My service port is 7000
fanzh
July 26, 2024, 5:26am
7
Thanks for the sharing! I are checking! will get back to you.
fanzh
July 26, 2024, 6:11am
8
here is a fix for the new added window can’t switch to full screen.
add the code in function bus_callback of \opt\nvidia\deepstream\deepstream-7.0\sources\apps\sample_apps\deepstream-app\deepstream_app.c
g_print("new stream added [%d:%s:%s]\n\n\n\n", sensorInfo.source_id, sensorInfo.sensor_id, sensorInfo.sensor_name);
appCtx->config.num_source_sub_bins++; //new code
g_print("new stream removed [%d:%s]\n\n\n\n", sensorInfo.source_id, sensorInfo.sensor_id);
appCtx->config.num_source_sub_bins--; //new code
rebuild deepstream-test5.
system
Closed
August 12, 2024, 6:27am
10
