I’m running SuSE Linux Enterprise 15 on my Lenovo T580. It has an optimus card with nvidia MX150. I started with driver 390.87 and got everything working via nvidia + modeset config and “xrandr --setprovideroutputsource modesetting NVIDIA-0;xrandr --auto”.
While running on AC power I set performance mode to maximum in nvidia-settings, ran “glmark2 --fullscreen” and came up with a score of about 2000. So far so good.
Now sth. has happened during the last two months that has cut the glmark2 core down by more tha 50% (score 900). I haven’t changed anything in my X config or the nvidia driver, but just comparing the first two benchmarks shows the difference (I recorded the output from the initial run):
Two months ago:
glmark2 2017.07
OpenGL Information
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: GeForce MX150/PCIe/SSE2
GL_VERSION: 4.6.0 NVIDIA 390.87
[build] use-vbo=false: FPS: 1990 FrameTime: 0.503 ms
[build] use-vbo=true: FPS: 3025 FrameTime: 0.331 ms
Today:
glmark2 2017.07
OpenGL Information
[build] use-vbo=false: FPS: 1236 FrameTime: 0.809 ms
[build] use-vbo=true: FPS: 1336 FrameTime: 0.749 ms
I reinstalled drivers and kernel, rebooted, also tried the G05 driver for SLED 15, i.e.nivida driver 430.26, but the benchmark results are the same. There is no composition manager running (which would indeed cut the performance by 50%), I tried as root with “startx” and as user with login via gdm, using Gnome, KDE and basic WMs like twm and fvvm2. All the same.
What I see in nvidia-settings is the graphics clock never goes above 427 Mhz although it’s running in “performance level 3” with graphics clock max = 1911Mhz. In idle mode it’s at 370 Mhz, with glmark2 running it goes up to 427Mhz. “Preferred Mode” is at “Prefer maximum Performance” all the time. Seems to be the same problem as in https://forum.manjaro.org/t/nvidia-card-stuck-at-low-clock-frequency-405mhz/85838. This worked fine initially because I remember how I was watching the clock going up and down in adaptive mode and wondered how it jumped to almost maximum clock when just moving some windows around on the desktop.
In Windows 10 the problem doesn’t exist, the clock jumps up to about 1500Mhz when starting some 3D programs, so it’s a linux driver problem.
Using “PowerMizerEnable=0x1; PerfLevelSrc=0x3322; PowerMizerDefaultAC=0x1” in xorg.conf doesn’t help. nvidia-smi shows all “Clocks Throttle Reasons” as “Not Active”, so I’ve no idea what makes the GPU clock stay down. Below is the output of “nvidia-smi -q”.
Does anyone have any idea what could lock the GPU clock at this low speed?
cu,
Frank
==============NVSMI LOG==============
Timestamp : Sun Sep 8 23:16:25 2019
Driver Version : 430.26
CUDA Version : 10.2
Attached GPUs : 1
GPU 00000000:02:00.0
Product Name : GeForce MX150
Product Brand : GeForce
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : Enabled
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-742a84c2-d7f4-b399-d405-e97cabc40969
Minor Number : 0
VBIOS Version : 86.08.28.00.64
MultiGPU Board : No
Board ID : 0x200
GPU Part Number : N/A
Inforom Version
Image Version : N/A
OEM Object : N/A
ECC Object : N/A
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization mode : None
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x02
Device : 0x00
Domain : 0x0000
Device Id : 0x1D1010DE
Bus Id : 00000000:02:00.0
Sub System Id : 0x00000000
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 4x
Current : 4x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 765000 KB/s
Rx Throughput : 12000 KB/s
Fan Speed : N/A
Performance State : P0
Idle : Not Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 2002 MiB
Used : 65 MiB
Free : 1937 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Compute Mode : Default
Utilization
Gpu : 100 %
Memory : 40 %
Encoder : N/A
Decoder : N/A
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Temperature
GPU Current Temp : 58 C
GPU Shutdown Temp : 102 C
GPU Slowdown Temp : 97 C
GPU Max Operating Temp : 94 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : N/A
Power Draw : N/A
Power Limit : N/A
Default Power Limit : N/A
Enforced Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : 420 MHz
SM : 420 MHz
Memory : 3003 MHz
Video : 1506 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1911 MHz
SM : 1911 MHz
Memory : 3004 MHz
Video : 1708 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes
Process ID : 26365
Type : G
Used GPU Memory : 61 MiB
Process ID : 28572
Type : G
Used GPU Memory : 3 MiB
