on this new computer with 5060ti using forge flux i cannot generate an image getting following error which seems to indicate pytorch is not supporting this card RuntimeError: CUDA error: device kernel image is invalid
CUDA kernel errors might be asynchronously reported at some other API call, so the stacktrace below might be incorrect.
For debugging consider passing CUDA_LAUNCH_BLOCKING=1
Compile with TORCH_USE_CUDA_DSA to enable device-side assertions.
