Hallo, I’m trying to set up an new virtural environment and run the model, but the following error shows up: RuntimeError: CUDA error: no kernel image is available for execution on the device
The system I am using is:
- Ubuntu 20.04
- laptop GeForce RTX 3070
- Driver Version: 510.73.05
torch=1.2.0in virtualenv environment - install cuda 10.0 with
.runfile, also check withnvcc -V
A simple test has been launched:
import torch
a = torch.randn(1,2,3).cuda()
print(a)
It works but too long! (about 2-3min) as:
tensor([[[ 0.9284, -0.6863, 1.5324],
[-0.6943, -0.7309, 0.4542]]], device='cuda:0')
When I run the network model, the program also takes long and finally raise:
Could you please give me some advice? Thanks in advance!
