The Message I am getting is :
Unexpected Error
daemon not running: could not dial ‘spark-2d2e’: ssh: handshake failed: ssh: unable to authenticate, attempted methods [none publickey], no supported methods remain
Unexpected Error
The error is about SSH authentication, not the daemon itself.
That means:
Your client reached spark-2d2e
Tried to log in with either no credentials or a public key
The DGX Spark did not accept any of those, so SSH gives up
try the following:
ssh -vvv spark@spark-2d2e
Look for lines like Offering public key and Authentication failed.
If you see no key offered, your local SSH config is the problem.
On the Mac/workstation, confirm you still have your private key:
ls -l ~/.ssh
Thank you. I have proceeded with deleting and recreating my user on the device and it seems to have worked.
for Windows go to C:\Users\username\.ssh edit with notepad and remove old names and re add host
