My GPU cannot support cuda stream priority
I tried to assign my CUDA streams to different levels of priority. However, I found that my GPU seems to only support one level. Is this because of the architecture (Ada Lovelace) of my GPU, the NVIDIA RTX 3500 Ada? Could I know if other GPUs in this series, such as the Nvidia L4, support priority? If there is any method to overcome this, I really want to try setting priority.
cuda.cuCtxGetStreamPriorityRange()
(<CUresult.CUDA_ERROR_NOT_INITIALIZED: 3>, 0, 0)
Kind regards.
I’m not aware of any modern GPU “not” supporting CUDA stream priority, and anyway CUDA_ERROR_NOT_INITIALIZED does not mean that. You have a improper setup or install of CUDA on your machine. There is not enough information here to suggest anything, but the first thing I would do is validate the CUDA install on your machine, using the installation guide appropriate/relevant for your operating system. If that checks out correctly, you may be attempting to do this in a setting that does not have a proper CUDA context. Make sure you have properly initialized a CUDA context prior to the call.
Hello Robert,
I found that my problem was that when I did a small test in a Python program, I didn’t initialize the CUDA API and context first. However, when I worked with the TensorRT library, even if I forgot the initialization, everything was fine. Could you please tell me the reason?
import numpy as np
from cuda import cuda
import tensorrt as trt
import time
import threading
import os
import re
import ctypes
# Use os.getcwd() to get the current working directory
current_dir = os.getcwd()
# Regular expression to match any content before "strait"
pattern = r'(.*?)/strait'
# Using search() to find the match
match = re.search(pattern, current_dir)
# Directory of Project
project_dir = match.group(1)
# Initialize TensorRT logger
TRT_LOGGER = trt.Logger(trt.Logger.INFO)
# Create a runtime object
runtime = trt.Runtime(TRT_LOGGER)
class tensorrt_context:
    def __init__(self, trt_model, priority):
        try:
            with open(trt_model, "rb") as f:
                deserialized_engine = f.read()
        except FileNotFoundError:
            print(f"Error: File {trt_model} not found")
            exit(1)
        self.engine = runtime.deserialize_cuda_engine(deserialized_engine)
        if self.engine is None:
            print("Error: Failed to deserialize the engine")
            exit(1)
        # Create an execution context
        self.context = self.engine.create_execution_context()
        if self.context is None:
            print("Error: Failed to create execution context")
            exit(1)
        # Input tensor name
        self.input_tensor_name = self.engine.get_tensor_name(0)
        # Output tensor name
        self.output_tensor_name = self.engine.get_tensor_name(1)
        # Minimum batch size for this engine model
        self.minimum_batch_size = self.engine.get_tensor_profile_shape(self.input_tensor_name, 0)[0][0]
        # Maximum batch size for this engine model
        self.max_batch_size = self.engine.get_tensor_profile_shape(self.input_tensor_name, 0)[-1][0]
        # Input data shape
        self.input_shape = tuple(self.engine.get_tensor_shape(self.input_tensor_name))[1:]
        # Output data shape
        self.output_shape = tuple(self.engine.get_tensor_shape(self.output_tensor_name))[1:]
        # Maximum batch input
        self.max_input_shape = (self.max_batch_size,) + self.input_shape
        # Maximum batch output
        self.max_output_shape = (self.max_batch_size,) + self.output_shape
        # Initialize a cuda stream
        self.init_cuda_stream(priority)
        self.device_memory_allocation()
        self.warm_up()
        self.test_data()
    def init_cuda_stream(self, priority):
        # Create a CUDA stream
        err_stream, self.stream = cuda.cuStreamCreateWithPriority(0, priority)
        #cuda.cuCtxGetStreamPriorityRange()
    def engine_data_type(self):
        if self.engine.get_tensor_dtype(self.input_tensor_name) == trt.DataType.FLOAT:
            self.data_byte = np.float32().itemsize
            return "FP32"
        elif self.engine.get_tensor_dtype(self.input_tensor_name) == trt.DataType.HALF:
            self.data_byte = np.float16().itemsize
            return "FP16"
        elif self.engine.get_tensor_dtype(self.input_tensor_name) == trt.DataType.INT32:
            self.data_byte = np.int32().itemsize
            return "INT32"
        elif self.engine.get_tensor_dtype(self.input_tensor_name) == trt.DataType.INT8:
            self.data_byte = np.int8().itemsize
            return "INT8"
    def data_generation(self, shape, empty=False):
        engine_data_type = self.engine_data_type()
        if engine_data_type == "FP32":
            if not empty:
                return np.random.random(shape).astype(np.float32)
            return np.empty(shape, dtype=np.float32)
    def device_memory_allocation(self):
        Input_Byte_Size = int(np.prod(self.max_input_shape) * np.float32().itemsize)
        Output_Byte_Size = int(np.prod(self.max_output_shape) * np.float32().itemsize)
        err_di, self.d_input = cuda.cuMemAllocAsync(Input_Byte_Size, self.stream)
        err_do, self.d_output = cuda.cuMemAllocAsync(Output_Byte_Size, self.stream)
        if err_di != cuda.CUresult(0) or err_do !=cuda.CUresult(0):
            print("Device memory allocation fail")
            exit(0)
    def cuda_stream_execution(self, h_input, d_input, h_output, d_output, Input_Byte_Size, Output_Byte_Size, Sream):
        cuda.cuMemcpyHtoDAsync(d_input, h_input.ctypes.data, Input_Byte_Size, Sream)
        # Execute the inference asynchronously
        self.context.execute_async_v3(stream_handle=Sream)
        # Transfer predictions back from the GPU asynchronously
        cuda.cuMemcpyDtoHAsync(h_output.ctypes.data, d_output, Output_Byte_Size, Sream)
        cuda.cuStreamSynchronize(Sream)
    def warm_up(self):
        minimum_input_shape = (self.minimum_batch_size,) + self.input_shape
        minimum_output_shape = (self.minimum_batch_size,) + self.output_shape
        warm_up_input = self.data_generation(minimum_input_shape)
        warm_up_output = self.data_generation(minimum_output_shape, True)
        # Setting the context binding
        self.context.set_input_shape(self.input_tensor_name, minimum_input_shape)
        assert self.context.all_binding_shapes_specified
        self.context.set_tensor_address(self.input_tensor_name, int(self.d_input))
        self.context.set_tensor_address(self.output_tensor_name, int(self.d_output))
        # Transfer input data to device asynchronously
        Input_Byte_Size = int(np.prod(minimum_input_shape) * self.data_byte)
        Output_Byte_Size = int(np.prod(minimum_output_shape) * self.data_byte)
        self.cuda_stream_execution(warm_up_input,
                                   self.d_input,
                                   warm_up_output,
                                   self.d_output,
                                   Input_Byte_Size,
                                   Output_Byte_Size,
                                   self.stream)
    def test(self):
        t1 = time.perf_counter_ns()
        Input_Byte_Size = int(np.prod(self.test_input_data_shape) * self.data_byte)
        Output_Byte_Size = int(np.prod(self.test_output_data_shape) * self.data_byte)
        self.cuda_stream_execution(self.test_h_input,
                                    self.d_input,
                                    self.test_h_output,
                                    self.d_output,
                                    Input_Byte_Size,
                                    Output_Byte_Size,
                                    self.stream)
        t2 = time.perf_counter_ns()
        print(f"test program response latency t2 - t1: {round(float((t2- t1) / 10**6), 1)} ms")
    def test_data(self):
        batch_size = 4
        self.test_input_data_shape = (batch_size,) + self.input_shape
        self.test_output_data_shape = (batch_size,) + self.output_shape
        self.test_h_input = self.data_generation(self.test_input_data_shape)
        self.test_h_output = self.data_generation(self.test_output_data_shape, True)
model_path = project_dir + '/strait/model/trt/'
start_timing = time.perf_counter_ns()
context1 = tensorrt_context(model_path + "resnet.trt",0)
end_timing = time.perf_counter_ns()
response_latency = round(float((end_timing - start_timing) / 10**6), 1) # Express latency in milliseconds
print(f"response latency: {response_latency} ms")
context2 = tensorrt_context(model_path + "resnet.trt", 0)
context1.test()
context2.test()
def run_test(context, context_id):
    context.test()
    print(f"Execution time for context{context_id}: {response_latency} ms")
cuda.cuProfilerStart()
# Create and start two threads
thread1 = threading.Thread(target=run_test, args=(context1, 1))
thread2 = threading.Thread(target=run_test, args=(context2, 2))
thread1.start()
thread2.start()
# Wait for both threads to finish
thread1.join()
thread2.join()
print(f"Total execution time for both tests: {response_latency} ms")
certain CUDA activities will automatically create a CUDA context if needed (in fact the entire CUDA runtime API works this way.)
I wouldn’t be able to comment further, but you are welcome to ask TRT questions on the forum for TRT questions.
