Description
Hi, I am trying to convert a onnx model to trt engine. My build script is as follows:
trtexec --fp16 --explicitBatch \
--workspace=2048 \
--onnx="model.onnx" --saveEngine="model.trt" \
--minShapes=\'input\':1x1x64x16 \
--optShapes=\'input\':1x1x64x320 \
--maxShapes=\'input\':2x1x64x3200
I am facing the following error while building the engine:
[11/26/2020-16:27:24] [E] [TRT] ../builder/myelin/codeGenerator.cpp (338) - Myelin Error in compileGraph: 69 (myelinExceededMemBudget : Exceeded mem budget of 4294967296. Need 5338390656
I am unable to find any relevant info about this library (myelin) to be able to figure this out. I’m wondering if there is any way to increase the maximum memory limit here? This error only comes up while building the engine with batch size > 1 (as i have added maxShapes = 2x1x64x3200). I have tested it with batch size 1 and it works well.
The onnx model that I want to convert is exported form pytorch with the following configuration:
x = torch.ones((2,1,64,640), dtype=torch.float)
torch.onnx.export(
model,
x,
'output.onnx',
input_names=['input'],
output_names=['scores'],
verbose=verbose,
opset_version=11,
dynamic_axes={'input': {0: 'batch', 3: 'width'}}) # batch and width can be dynamic
Additionally I have attached the model files and error log below.
Environment
TensorRT Version: 7.0.0.11
GPU Type: TITAN X (Pascal)
Nvidia Driver Version: 455
CUDA Version: 10.2
CUDNN Version: 7.6.5
Operating System + Version: Ubuntu 18.04
Python Version (if applicable): 3
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
log.txt (431.7 KB) model.txt (1.7 KB) modules.txt (9.5 KB)
Any help would be appreciated. Thanks.
