n00b error with cudaMemcpy
I did search for an answer to this on the forums but didn’t find one, here goes:
When I try to use cudaMemcpy everything compiles fine, but in debug mode I notice that it isnt actually copying from the host to device, here is the relevant section of code:
const int max_particles = 1000;
int main(){
	int a = 256;
	struct element{
		float x[max_particles];
		float p_x[max_particles];
	} particle; //The struct object for the elements of particles is called particle
Here be a section of code which reads values into particle.x and particle.p_x
	size_t size = a * sizeof(float); //Determine amount of memory  required for each variable
	//Create memory on the Host and assign pointers for each variable
	float* host_particle_x = (float*)malloc(size);
	float* host_particle_p_x = (float*)malloc(size);
	cout << "Allocating host memory and initialising...\n" << endl;
	//Initialise Host pointers with the determined variables
	host_particle_x = particle.x;
	host_particle_p_x = particle.p_x;
	//Create variables for the device
	float* device_particle_x;
	float* device_particle_p_x;
	cout << "Allocating Device memory..." << endl;
	//Allocate memory for the device variables
	cutilSafeCall(cudaMalloc((void**)&device_particle_x, size));
	cutilSafeCall(cudaMalloc((void**)&device_particle_p_x, size));
	cout << "Copying Host memory to Device memory..." << endl;
	//Copy the variables from the host memory to the device memory
	cutilSafeCall(cudaMemcpy(device_particle_x, host_particle_x, size, cudaMemcpyHostToDevice));
	cutilSafeCall(cudaMemcpy(device_particle_p_x, host_particle_p_x, size, cudaMemcpyHostToDevice));
Can anyone see what it is that I’m doing wrong?
Thank you in advance x
The just allocated host_particle_x, host_particle_p_x are overidden by particle.x, particle.p_x, which seems wrong(memory leak).
Maybe you want to do a “mempy(host_particle_x, particle.x, size)”?
Thankyou for the fast reply
I have semi-solved it, for some reason it works in release mode but not in debug mode?
I think your right Nighthawk, my host variables are abit redundant when they can be replaced with particle.x and particle.p_x, so I’ll change that
If you have any idea on how I can fix it for debug mode that would be great, but I can deal with it only working in release mode for now.
Many thanks x
Many thanks x
