I have the HQ Camera working with the 2GB nano without mods. gst with nvarguscamersrc works great but I am having problems with using v4l2-ctrl capturing raw images.
I am using the following command:
v4l2-ctl -d /dev/video0 --verbose --set-fmt-video=width=4032,height=3040,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw
The program just hangs and raw file is 0 bytes. Syslog shows tegra_channel_error_status:error 20022
may I know which sensor module it is?
could you please dump the pixel formats with below commands,
for example, $ v4l2-ctl -d /dev/video0 --list-formats-ext
thanks
I am using the Raspi HQ camera IMX477 sensor module.
the formats via v4l2-ctl are 4032x3040 @ 30fps and 1920x1080 @ 60fps.
The camera works fine with gst-launch + nvarguscamerasrc at the sepcified formats. v4l2-ctl can list the modes and query other information but wonāt save out a raw file.
please double confirm youāre assign correct width, height and pixel formats for v4l2 standard controls.
could you please exclude --stream-to to verify the sensor streams?
for example, $ v4l2-ctl -d /dev/video0 --set-fmt-video=width=4032,height=3040,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100.
it should output > for each captured frames.
thanks
Hi Jerry, I tried the command and Iām still experiencing the same hang condition. Here is the output:
$ v4l2-ctl -d /dev/video0 --verbose --set-fmt-video=width=4032,height=3040,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100
VIDIOC_QUERYCAP: ok
VIDIOC_S_EXT_CTRLS: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture:
Width/Height : 4032/3040
Pixel Format : āRG10ā
Field : None
Bytes per Line : 8064
Size Image : 24514560
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: ok no more ouput after this and hangs indefinitely
you may download the latest (i.e. R32.4.4) L4T sources release package for the source code.
for example,
hereās kernel sources of IMX477, $L4T_Sources/r32.4.4/Linux_for_Tegra/source/public/kernel/nvidia/drivers/media/i2c/imx477.c
FYI,
Iām also able to reproduce the issue with Nano-2GB/IMX477.
it seems v4l2-ctl is not working with IMX477 whereas nvarguscamerasrc works.
please having your use-case with nvarguscamersrc,
weāre going to check this v4l2 standard control failures internally, will update the status after we come out conclusions.
thanks
I just did a āsudo apt updateā and āsudo apt upgradeā and now the camera is no longer detected. Nvargus and v4l2-ctl --all says there is no camera.
itās kernel manually update, RPi IMX477 Support Nano 2GB.
while youāre doing system upgrade, it may refresh the kernel image to revert the changes.
thanks
FYI,
thereāre some changes for the latest L4T release, and it fixes the issue that v4l2-ctl is not working with IMX477 whereas nvarguscamerasrc works.
weāre having internal code-review, itās target for the next public JetPack release, (i.e. JetPack-4.6/ l4t-r32.6)
thanks
thatās correct, we have some bug fixes to address v4l2 raw capture failures.
the changes has been merged into JetPack-4.6 (l4t-r32.6), please download the latest Jetpack release for your development.
