(Nano) nvbufsurftransform: Could not get EGL display connection
I am running a pipeline without a monitor on the Nano through ssh.
The pipeline starts with v4l2src and ends with fakesink.
Also tried export DISPLAY=:0.
Please try ‘export DISPLAY=:1’ and check if you can get display information through ‘xrandr’.
Found solution
  1. Make sure DISPLAY is not set. Unset if necessary.
  2. Disable X11-forwarding.
