Nano orin Crash when using v4l2 call VIDIOC_STREAMON
I try to capture images with nano jetson orin and v42l with an imx678 sensor.
Everytime I start the stream bei VIDIOC_STREAMON (by call of ioctl), the system crashes:
[Mon Sep 18 12:09:59 2023] Unable to handle kernel paging request at virtual address 0000000001008880
[Mon Sep 18 12:09:59 2023] Mem abort info:
[Mon Sep 18 12:09:59 2023]   ESR = 0x96000044
[Mon Sep 18 12:09:59 2023]   EC = 0x25: DABT (current EL), IL = 32 bits
[Mon Sep 18 12:09:59 2023]   SET = 0, FnV = 0
[Mon Sep 18 12:09:59 2023]   EA = 0, S1PTW = 0
[Mon Sep 18 12:09:59 2023] Data abort info:
[Mon Sep 18 12:09:59 2023]   ISV = 0, ISS = 0x00000044
[Mon Sep 18 12:09:59 2023]   CM = 0, WnR = 1
[Mon Sep 18 12:09:59 2023] user pgtable: 4k pages, 48-bit VAs, pgdp=00000000a3c75000
[Mon Sep 18 12:09:59 2023] [0000000001008880] pgd=0000000000000000, p4d=0000000000000000
[Mon Sep 18 12:09:59 2023] Internal error: Oops: 96000044 [#1] PREEMPT SMP
The exactly the same code does work without any problems on an nano jetson (without orin).
I can use to capture the v4l2-ctrl tool without any problem. The v4l2 capabilities clearly shows, that capture mode is true.
What could be the reason for this behaviour?
best regards
Bernhard
Suppose you need implement new driver for Orin due to kernel version is different.
