A problem has been encountered, when I use v4l2-ctrl to test camera.
sdk version: JetPack 4.2.1 - L4T R32.1
test cmd: v4l2-ctl --set-fmt-video=width=1280,height=768,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1000 -d /dev/video0
It was normal at first, but it was abnormal when the camera does not output images suddenly(maybe camera died or lines broken). The dmesg is shown below:
[ 534.490310] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 534.490458] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 534.490621] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 534.493051] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 537.046313] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 537.046454] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 537.046585] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 537.046721] tegra194-vi5 15c10000.vi: unexpected response from camera processor
[ 537.046841] video4linux video0: vi capture release failed
[ 537.046932] tegra194-vi5 15c10000.vi: fatal: error recovery failed
[ 537.542788] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 537.542940] Mem abort info:
[ 537.542992] ESR = 0x96000005
[ 537.543046] Exception class = DABT (current EL), IL = 32 bits
[ 537.543139] SET = 0, FnV = 0
[ 537.543194] EA = 0, S1PTW = 0
[ 537.543245] Data abort info:
[ 537.543292] ISV = 0, ISS = 0x00000005
[ 537.543360] CM = 0, WnR = 0
[ 537.543419] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc177404000
[ 537.543520] [0000000000000000] *pgd=0000000000000000, *pud=0000000000000000
[ 537.543655] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 537.543754] Modules linked in: can_raw can fuse i2c_camera_driver(O) overlay mvsw61xx 8021q garp mrp nvs_bmi160 nvs nvgpu binfmt_misc nfsd nfs_acl ip_tables x_tables
[ 537.544264] CPU: 5 PID: 12993 Comm: v4l2-ctl Tainted: G W O 4.9.140+ #1
[ 537.544816] Hardware name: jetson-xavier (DT)
[ 537.545181] task: ffffffc1719e0e00 task.stack: ffffffc17404c000
[ 537.545630] PC is at exit_creds+0x2c/0x80
[ 537.545934] LR is at __put_task_struct+0x4c/0x148
[ 537.549599] pc : [] lr : [] pstate: 60400045
[ 537.557205] sp : ffffffc17404fa10
[ 537.560621] x29: ffffffc17404fa10 x28: ffffffc1719e0e00
[ 537.566214] x27: 0000000000000009 x26: ffffffc32ddb1dc0
[ 537.571557] x25: ffffffc182125810 x24: 0000000000000001
[ 537.576895] x23: ffffffc3e91e4048 x22: ffffffc3ecfa2b58
[ 537.582233] x21: ffffffc32620e230 x20: 0000000000000000
[ 537.587400] x19: ffffffc32620e200 x18: 0000007f922eda70
[ 537.593091] x17: 0000007f92263f90 x16: ffffffbf0bf27de0
[ 537.599116] x15: 000000000000000a x14: ffffffbf00000000
[ 537.604549] x13: 00000000000001a2 x12: 0000000000000fa0
[ 537.610060] x11: 000000000000000b x10: 0000000000000a20
[ 537.615857] x9 : ffffffc17404f850 x8 : ffffffc1719e1880
[ 537.621867] x7 : fefefeff646c606d x6 : 000000000b44fc4a
[ 537.627121] x5 : 0000000000000400 x4 : 0000000000000000
[ 537.632714] x3 : 00000000000000be x2 : 0000000000000000
[ 537.637798] x1 : 0000000000000000 x0 : 00000000ffffffff
[ 537.644814] Process v4l2-ctl (pid: 12993, stack limit = 0xffffffc17404c000)
[ 537.651441] Call trace:
[ 537.653812] [] exit_creds+0x2c/0x80
[ 537.658368] [] __put_task_struct+0x4c/0x148
[ 537.663700] [] kthread_stop+0x1e0/0x1e8
[ 537.669036] [] vi5_channel_stop_kthreads+0x40/0x58
[ 537.675156] [] vi5_channel_stop_streaming+0x48/0xa8
[ 537.681303] [] tegra_channel_stop_streaming+0x34/0x48
[ 537.687239] [] __vb2_queue_cancel+0x3c/0x170
[ 537.693095] [] vb2_core_queue_release+0x2c/0x58
[ 537.698957] [] _vb2_fop_release+0x88/0xa8
[ 537.704292] [] tegra_channel_close+0x58/0x128
[ 537.709987] [] v4l2_release+0x4c/0x98
[ 537.714890] [] __fput+0x94/0x1d0
[ 537.719954] [] ____fput+0x20/0x30
[ 537.724771] [] task_work_run+0xc0/0xe0
[ 537.730024] [] do_exit+0x2b8/0x9d8
[ 537.735177] [] do_group_exit+0x3c/0xa0
[ 537.740517] [] get_signal+0x29c/0x590
[ 537.745723] [] do_signal+0x168/0x4e0
[ 537.750694] [] do_notify_resume+0x90/0xb0
[ 537.756270] [] work_pending+0x8/0x10
[ 537.761611] —[ end trace 867157b046591f9a ]—
[ 537.774769] Fixing recursive fault but reboot is needed!
And at this time, the v4l2-ctrl program cannot be killed by “ctrl+c” and “kill -9 pid”.
root@xavier[1]:~$ v4l2-ctl --set-fmt-video=width=1280,height=768,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1000 -d /dev/video0
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 40.19 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 40.09 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 40.06 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 40.04 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 40.03 fps
<^C^C^C^C^C
root@xavier[1]:~$ ps -e | grep v4l2
12993 pts/4 00:00:00 v4l2-ctl
root@xavier[1]:~$
root@xavier[1]:~$ kill -9 12993
root@xavier[1]:~$
I think, whatever happens to the camera, kernel should not oops and program should not can’t be killed.
