Now,I can capture images from 4 cameras simultaneously in one Max9286 with gst-launch-1.0 . But if I used v4l2-ctl, capture failed. To reduce the use of cpu, I must choose v4l2-ctl. Error log is following.
[ 84.922733] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 0, err_data 512, id = 0
[ 84.962788] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160, id = 0
[ 84.962811] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 112, err_data 6291552, id = 3
[ 84.962828] tegra194-vi5 15c10000.vi: corr_err: discarding frame 2, flags: 0, err_data 512, id = 3
[ 84.962872] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 96, err_data 4194400, id = 2
[ 84.963033] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 96, err_data 4194400, id = 1
[ 84.967278] tegra194-vi5 15c10000.vi: corr_err: discarding frame 2, flags: 112, err_data 6291552, id = 1
[ 84.967531] tegra194-vi5 15c10000.vi: corr_err: discarding frame 2, flags: 112, err_data 6291552, id = 2
[ 84.967723] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160, id = 3
[ 85.002795] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160, id = 0
[ 85.042809] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 112, err_data 6291552, id = 2
[ 85.042962] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 3
[ 85.042969] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 112, err_data 6291552, id = 1
[ 85.043089] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583008, id = 0
[ 85.043174] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 0, err_data 131072, id = 3
[ 85.082839] tegra194-vi5 15c10000.vi: corr_err: discarding frame 4, flags: 112, err_data 6291552, id = 2
[ 85.083073] tegra194-vi5 15c10000.vi: corr_err: discarding frame 4, flags: 96, err_data 4194400, id = 1
[ 85.083170] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 3
[ 85.083211] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160, id = 0
[ 85.122967] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160, id = 0
[ 85.123173] tegra194-vi5 15c10000.vi: corr_err: discarding frame 5, flags: 112, err_data 6291552, id = 1
[ 85.123362] tegra194-vi5 15c10000.vi: corr_err: discarding frame 5, flags: 112, err_data 6291552, id = 3
[ 85.123373] tegra194-vi5 15c10000.vi: corr_err: discarding frame 5, flags: 96, err_data 4194400, id = 2
[ 85.127491] tegra194-vi5 15c10000.vi: corr_err: discarding frame 6, flags: 112, err_data 6291552, id = 1
[ 85.162631] tegra194-vi5 15c10000.vi: corr_err: discarding frame 6, flags: 112, err_data 14680160, id = 3
[ 85.162642] tegra194-vi5 15c10000.vi: corr_err: discarding frame 6, flags: 112, err_data 6291552, id = 2
[ 85.162932] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160, id = 0
[ 85.202977] tegra194-vi5 15c10000.vi: corr_err: discarding frame 7, flags: 96, err_data 4194400, id = 1
[ 85.202986] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583008, id = 0
[ 85.203009] tegra194-vi5 15c10000.vi: corr_err: discarding frame 7, flags: 112, err_data 6291552, id = 2
[ 85.203024] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 3
[ 85.203035] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072, id = 3
[ 85.203815] tegra194-vi5 15c10000.vi: corr_err: discarding frame 8, flags: 0, err_data 512, id = 1
[ 85.207375] tegra194-vi5 15c10000.vi: corr_err: discarding frame 8, flags: 112, err_data 6291552, id = 2
[ 85.207566] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 3
[ 85.207634] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160, id = 1
[ 85.242948] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160, id = 0
[ 85.282797] tegra194-vi5 15c10000.vi: corr_err: discarding frame 9, flags: 112, err_data 6291552, id = 2
[ 85.283053] tegra194-vi5 15c10000.vi: corr_err: discarding frame 9, flags: 112, err_data 6291552, id = 3
[ 85.283060] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400, id = 1
[ 85.283065] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160, id = 0
[ 85.283076] tegra194-vi5 15c10000.vi: corr_err: discarding frame 9, flags: 0, err_data 131072, id = 1
[ 85.322975] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583008, id = 0
[ 85.323200] tegra194-vi5 15c10000.vi: corr_err: discarding frame 10, flags: 112, err_data 6291552, id = 2
[ 85.323245] tegra194-vi5 15c10000.vi: corr_err: discarding frame 10, flags: 112, err_data 6291552, id = 3
[ 85.323285] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 1
[ 85.362987] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583008, id = 0
[ 85.363108] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 3
[ 85.363156] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072, id = 3
[ 85.363196] tegra194-vi5 15c10000.vi: corr_err: discarding frame 11, flags: 96, err_data 4194400, id = 2
[ 85.363263] tegra194-vi5 15c10000.vi: corr_err: discarding frame 11, flags: 112, err_data 6291552, id = 1
[ 85.403005] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160, id = 0
[ 85.403177] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 3
[ 85.403182] tegra194-vi5 15c10000.vi: corr_err: discarding frame 12, flags: 112, err_data 6291552, id = 2
[ 85.403218] tegra194-vi5 15c10000.vi: corr_err: discarding frame 12, flags: 96, err_data 4194400, id = 1
[ 85.442997] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 12583008, id = 0
[ 85.443196] tegra194-vi5 15c10000.vi: corr_err: discarding frame 13, flags: 112, err_data 6291552, id = 3
[ 85.443218] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 1
[ 85.443240] tegra194-vi5 15c10000.vi: corr_err: discarding frame 13, flags: 112, err_data 6291552, id = 2
[ 85.443273] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072, id = 1
[ 85.447583] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400, id = 1
[ 85.482961] tegra194-vi5 15c10000.vi: corr_err: discarding frame 14, flags: 112, err_data 6291552, id = 2
[ 85.483103] tegra194-vi5 15c10000.vi: corr_err: discarding frame 14, flags: 112, err_data 14680160, id = 3
[ 85.483182] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160, id = 0
[ 85.523051] tegra194-vi5 15c10000.vi: corr_err: discarding frame 15, flags: 96, err_data 4194400, id = 1
[ 85.523074] tegra194-vi5 15c10000.vi: corr_err: discarding frame 15, flags: 112, err_data 6291552, id = 2
[ 85.523090] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 3
[ 85.523102] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072, id = 3
[ 85.523110] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160, id = 0
[ 85.563106] tegra194-vi5 15c10000.vi: corr_err: discarding frame 16, flags: 96, err_data 4194400, id = 2
[ 85.563145] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 3
[ 85.563162] tegra194-vi5 15c10000.vi: corr_err: discarding frame 16, flags: 112, err_data 6291552, id = 1
[ 85.563232] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160, id = 0
[ 85.603103] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160, id = 0
[ 85.603153] tegra194-vi5 15c10000.vi: corr_err: discarding frame 17, flags: 112, err_data 6291552, id = 3
[ 85.603159] tegra194-vi5 15c10000.vi: corr_err: discarding frame 17, flags: 112, err_data 6291552, id = 2
[ 85.603647] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400, id = 1
[ 85.603830] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072, id = 1
[ 85.643118] tegra194-vi5 15c10000.vi: corr_err: discarding frame 18, flags: 112, err_data 6291552, id = 2
[ 85.643159] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400, id = 1
[ 85.643166] tegra194-vi5 15c10000.vi: corr_err: discarding frame 18, flags: 96, err_data 4194400, id = 3
[ 85.643182] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160, id = 0
[ 85.682967] tegra194-vi5 15c10000.vi: corr_err: discarding frame 19, flags: 112, err_data 6291552, id = 1
[ 85.683048] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160, id = 3
[ 85.683087] tegra194-vi5 15c10000.vi: corr_err: discarding frame 19, flags: 112, err_data 6291552, id = 2
[ 85.683133] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 512, id = 3
[ 85.683183] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160, id = 0
[ 85.723089] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160, id = 0
[ 85.723106] tegra194-vi5 15c10000.vi: corr_err: discarding frame 20, flags: 96, err_data 4194400, id = 1
[ 85.723213] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400, id = 3
[ 85.723259] tegra194-vi5 15c10000.vi: corr_err: discarding frame 20, flags: 112, err_data 6291552, id = 2
[ 85.762963] tegra194-vi5 15c10000.vi: corr_err: discarding frame 21, flags: 112, err_data 6291552, id = 2
[ 85.763177] tegra194-vi5 15c10000.vi: corr_err: discarding frame 21, flags: 112, err_data 6291552, id = 3
[ 85.763184] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 1
[ 85.763202] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072, id = 1
[ 85.763233] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160, id = 0
[ 85.803119] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160, id = 0
[ 85.803182] tegra194-vi5 15c10000.vi: corr_err: discarding frame 22, flags: 96, err_data 4194400, id = 3
[ 85.803257] tegra194-vi5 15c10000.vi: corr_err: discarding frame 22, flags: 112, err_data 6291552, id = 2
[ 85.803291] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 1
[ 85.843172] tegra194-vi5 15c10000.vi: corr_err: discarding frame 23, flags: 112, err_data 6291552, id = 1
[ 85.843395] tegra194-vi5 15c10000.vi: corr_err: discarding frame 23, flags: 96, err_data 4194400, id = 2
[ 85.843476] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 3
[ 85.843489] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072, id = 3
[ 85.843557] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 14680160, id = 0
[ 85.848963] tegra194-vi5 15c10000.vi: corr_err: discarding frame 24, flags: 96, err_data 4194400, id = 1
[ 85.883044] tegra194-vi5 15c10000.vi: corr_err: discarding frame 24, flags: 112, err_data 6291552, id = 2
[ 85.883064] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 6291552, id = 3
[ 85.883272] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160, id = 0
