Hi ShaneCCC
thanks for your reply
When I run command of “v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=3”
the kernel log output the below error:
[ 1360.807752] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 0, err_data 64
[ 1360.853154] tegra194-vi5 15c10000.vi: corr_err: discarding frame 4, flags: 0, err_data 64
[ 1360.898585] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 0, err_data 64
[ 1360.944045] tegra194-vi5 15c10000.vi: corr_err: discarding frame 2, flags: 0, err_data 64
[ 1360.989443] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 0, err_data 64
[ 1361.034886] tegra194-vi5 15c10000.vi: corr_err: discarding frame 4, flags: 0, err_data 64
[ 1361.080314] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 0, err_data 64
[ 1361.125747] tegra194-vi5 15c10000.vi: corr_err: discarding frame 2, flags: 0, err_data 64
[ 1361.171170] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 0, err_data 64
[ 1361.216606] tegra194-vi5 15c10000.vi: corr_err: discarding frame 4, flags: 0, err_data 64
[ 1361.262051] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 0, err_data 64
[ 1361.307618] tegra194-vi5 15c10000.vi: corr_err: discarding frame 2, flags: 0, err_data 64
[ 1361.352938] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 0, err_data 64
[ 1361.398347] tegra194-vi5 15c10000.vi: corr_err: discarding frame 4, flags: 0, err_data 64
[ 1361.443826] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 0, err_data 64
[ 1361.489247] tegra194-vi5 15c10000.vi: corr_err: discarding frame 2, flags: 0, err_data 64
[ 1361.534677] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 0, err_data 64
[ 1361.580074] tegra194-vi5 15c10000.vi: corr_err: discarding frame 4, flags: 0, err_data 64
[ 1361.625503] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 0, err_data 64
[ 1361.670939] tegra194-vi5 15c10000.vi: corr_err: discarding frame 2, flags: 0, err_data 64
[ 1361.716362] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 0, err_data 64
[ 1361.761813] tegra194-vi5 15c10000.vi: corr_err: discarding frame 4, flags: 0, err_data 64
[ 1361.807250] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 0, err_data 64
[ 1361.852676] tegra194-vi5 15c10000.vi: corr_err: discarding frame 2, flags: 0, err_data 64
[ 1361.898103] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 0, err_data 64
[ 1361.943552] tegra194-vi5 15c10000.vi: corr_err: discarding frame 4, flags: 0, err_data 64
[ 1361.988965] tegra194-vi5 15c10000.vi: corr_err: discarding frame 1, flags: 0, err_data 64
[ 1362.034420] tegra194-vi5 15c10000.vi: corr_err: discarding frame 2, flags: 0, err_data 64
[ 1362.079840] tegra194-vi5 15c10000.vi: corr_err: discarding frame 3, flags: 0, err_data 64
[ 1362.125269] tegra194-vi5 15c10000.vi: corr_err: discarding frame 4, flags: 0, err_data 64
open the trace log, it shows:
tracer: nop
entries-in-buffer/entries-written: 8669/8669 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:2-1179 [000] .... 1093.287659: rtos_queue_peek_from_isr_failed: tstamp:34527936963 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1093.455682: rtos_queue_peek_from_isr_failed: tstamp:34532936963 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1093.623621: rtos_queue_peek_from_isr_failed: tstamp:34537936967 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1093.735624: rtos_queue_peek_from_isr_failed: tstamp:34542936963 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1093.903592: rtos_queue_peek_from_isr_failed: tstamp:34547936976 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1094.071596: rtos_queue_peek_from_isr_failed: tstamp:34552936971 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1094.239607: rtos_queue_peek_from_isr_failed: tstamp:34557936984 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1094.407595: rtos_queue_peek_from_isr_failed: tstamp:34562936962 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1094.575611: rtos_queue_peek_from_isr_failed: tstamp:34567936966 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1094.743599: rtos_queue_peek_from_isr_failed: tstamp:34572936959 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1094.855588: rtos_queue_peek_from_isr_failed: tstamp:34577936963 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1095.023622: rtos_queue_peek_from_isr_failed: tstamp:34582936959 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1095.191598: rtos_queue_peek_from_isr_failed: tstamp:34587936966 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1095.359584: rtos_queue_peek_from_isr_failed: tstamp:34592936965 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1095.527615: rtos_queue_peek_from_isr_failed: tstamp:34597936962 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1095.695595: rtos_queue_peek_from_isr_failed: tstamp:34602936979 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1095.863600: rtos_queue_peek_from_isr_failed: tstamp:34607936974 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1095.975594: rtos_queue_peek_from_isr_failed: tstamp:34612936969 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1096.143590: rtos_queue_peek_from_isr_failed: tstamp:34617936967 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1096.311616: rtos_queue_peek_from_isr_failed: tstamp:34622936966 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1096.479607: rtos_queue_peek_from_isr_failed: tstamp:34627936966 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1096.647669: rtos_queue_peek_from_isr_failed: tstamp:34632936966 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1096.819663: rtos_queue_peek_from_isr_failed: tstamp:34637936962 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1096.931614: rtos_queue_peek_from_isr_failed: tstamp:34642936965 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1097.099606: rtos_queue_peek_from_isr_failed: tstamp:34647936961 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1097.267590: rtos_queue_peek_from_isr_failed: tstamp:34652936963 queue:0x0bcbcf78
kworker/0:2-1179 [000] .... 1097.435651: rtos_queue_peek_from_isr_failed: tstamp:34657634526 queue:0x0bcbcf78
v4l2-ctl-20483 [002] .... 1360.689391: tegra_channel_open: vi-output, ar0231 8-0018
v4l2-ctl-20483 [002] .... 1360.692043: tegra_channel_set_power: ar0231 8-0018 : 0x1
v4l2-ctl-20483 [002] .... 1360.692068: camera_common_s_power: status : 0x1
v4l2-ctl-20483 [000] .... 1360.692693: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
v4l2-ctl-20483 [000] .... 1360.692704: csi_s_power: enable : 0x1
v4l2-ctl-20483 [001] .... 1360.703871: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
v4l2-ctl-20483 [001] .... 1360.716585: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-20483 [001] .... 1360.722582: tegra_channel_set_stream: 15a00000.nvcsi--4 : 0x1
v4l2-ctl-20483 [001] .... 1360.722588: csi_s_stream: enable : 0x1
v4l2-ctl-20483 [001] .... 1360.722598: tegra_channel_set_stream: ar0231 8-0018 : 0x1
kworker/0:3-20341 [000] .... 1360.759626: rtos_queue_peek_from_isr_failed: tstamp:42886120686 queue:0x0bcbcf78
kworker/0:3-20341 [000] .... 1360.759631: rtcpu_start: tstamp:42886124497
kworker/0:3-20341 [000] .... 1360.759635: rtos_queue_send_from_isr_failed: tstamp:42886242808 queue:0x0bcb41f8
kworker/0:3-20341 [000] .... 1360.759637: rtos_queue_send_from_isr_failed: tstamp:42886243032 queue:0x0bcb8a60
kworker/0:3-20341 [000] .... 1360.759638: rtos_queue_send_from_isr_failed: tstamp:42886243256 queue:0x0bcba5e0
kworker/0:3-20341 [000] .... 1360.759676: rtos_queue_send_from_isr_failed: tstamp:42886243474 queue:0x0bcbb3a0
kworker/0:3-20341 [000] .... 1360.759678: rtos_queue_send_from_isr_failed: tstamp:42886243692 queue:0x0bcbc160
kworker/0:3-20341 [000] .... 1360.759681: rtcpu_string: tstamp:42886244325 id:0x04010000 str:"Configuring VI GoS.
kworker/0:3-20341 [000] … 1360.759716: rtcpu_string: tstamp:42886244592 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:3-20341 [000] … 1360.759730: rtcpu_string: tstamp:42886244920 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:3-20341 [000] … 1360.759743: rtcpu_string: tstamp:42886245284 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:3-20341 [000] … 1360.759755: rtcpu_string: tstamp:42886245597 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:3-20341 [000] … 1360.759764: rtcpu_string: tstamp:42886245905 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:3-20341 [000] … 1360.759773: rtcpu_string: tstamp:42886246223 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:3-20341 [000] … 1360.759782: rtcpu_string: tstamp:42886254205 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol versi”
kworker/0:3-20341 [000] … 1360.759785: rtcpu_string: tstamp:42886254396 id:0x04010000 str:"on 2.2
kworker/0:3-20341 [000] … 1360.759796: rtos_queue_send_from_isr_failed: tstamp:42886283600 queue:0x0bcb41f8
kworker/0:3-20341 [000] … 1360.759798: rtos_queue_send_from_isr_failed: tstamp:42886283881 queue:0x0bcb8a60
kworker/0:3-20341 [000] … 1360.759799: rtos_queue_send_from_isr_failed: tstamp:42886284108 queue:0x0bcba5e0
kworker/0:3-20341 [000] … 1360.759801: rtos_queue_send_from_isr_failed: tstamp:42886284326 queue:0x0bcbb3a0
kworker/0:3-20341 [000] … 1360.759803: rtos_queue_send_from_isr_failed: tstamp:42886284544 queue:0x0bcbc160
kworker/0:3-20341 [000] … 1360.759804: rtcpu_string: tstamp:42886285765 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:3-20341 [000] … 1360.759815: rtos_queue_send_from_isr_failed: tstamp:42886474028 queue:0x0bcb41f8
kworker/0:3-20341 [000] … 1360.759817: rtos_queue_send_from_isr_failed: tstamp:42886474178 queue:0x0bcb8a60
kworker/0:3-20341 [000] … 1360.759819: rtos_queue_send_from_isr_failed: tstamp:42886474331 queue:0x0bcba5e0
kworker/0:3-20341 [000] … 1360.759820: rtos_queue_send_from_isr_failed: tstamp:42886474476 queue:0x0bcbb3a0
kworker/0:3-20341 [000] … 1360.759822: rtos_queue_send_from_isr_failed: tstamp:42886474624 queue:0x0bcbc160
kworker/0:3-20341 [000] … 1360.759824: rtcpu_nvcsi_intr: tstamp:42886477219 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000089
kworker/0:3-20341 [000] … 1360.759826: rtcpu_nvcsi_intr: tstamp:42886477219 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000088
kworker/0:3-20341 [000] … 1360.759828: rtcpu_vinotify_error: tstamp:42886481049 tag:CSIMUX_STREAM channel:0x00 frame:16 vi_tstamp:42886480424 data:0x00000100
kworker/0:3-20341 [000] … 1360.759830: rtcpu_vinotify_error: tstamp:42886481936 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:42886481317 data:0x00000100
kworker/0:3-20341 [000] … 1360.759832: rtcpu_vinotify_event: tstamp:42886566934 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:40921322848 data:0x10000000
kworker/0:3-20341 [000] … 1360.759834: rtcpu_vinotify_event: tstamp:42886567076 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:40921326688 data:0x31000001
kworker/0:3-20341 [000] … 1360.759836: rtcpu_vinotify_event: tstamp:42886567237 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:40921327680 data:0x07020001
kworker/0:3-20341 [000] … 1360.759837: rtcpu_vinotify_event: tstamp:42886567372 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:40921388160 data:0x10000000
kworker/0:3-20341 [000] … 1360.759839: rtcpu_vinotify_event: tstamp:42886567529 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:40921395200 data:0x31000002
kworker/0:3-20341 [000] … 1360.759840: rtcpu_vinotify_event: tstamp:42886567674 tag:CSIMUX_STREAM channel:0x00 frame:16 vi_tstamp:42886480424 data:0x00000100
kworker/0:3-20341 [000] … 1360.759842: rtcpu_vinotify_event: tstamp:42886567840 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:42886481317 data:0x00000100
kworker/0:3-20341 [000] … 1360.759843: rtcpu_vinotify_error: tstamp:42886791758 tag:CHANSEL_NOMATCH channel:0x44 frame:2 vi_tstamp:42886791084 data:0x000003c9
kworker/0:3-20341 [000] … 1360.759845: rtcpu_vinotify_event: tstamp:42886879966 tag:FS channel:0x01 frame:2 vi_tstamp:42886788669 data:0x00000012
kworker/0:3-20341 [000] … 1360.759847: rtcpu_vinotify_event: tstamp:42886880123 tag:CHANSEL_NOMATCH channel:0x44 frame:2 vi_tstamp:42886791084 data:0x000003c9
kworker/0:3-20341 [000] … 1360.815628: rtcpu_vinotify_event: tstamp:42887819051 tag:FS channel:0x00 frame:3 vi_tstamp:42887813762 data:0x00000012
kworker/0:3-20341 [000] … 1360.815633: rtcpu_vinotify_event: tstamp:42887819216 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:42887813763 data:0x00000000
kworker/0:3-20341 [000] … 1360.815634: rtcpu_vinotify_event: tstamp:42887819353 tag:CHANSEL_PXL_SOF channel:0x23 frame:3 vi_tstamp:42887816199 data:0x00000001
kworker/0:3-20341 [000] … 1360.815636: rtcpu_vinotify_event: tstamp:42887819511 tag:RESERVED_19 channel:0x23 frame:3 vi_tstamp:40970257120 data:0x08020001
kworker/0:3-20341 [000] … 1360.815638: rtcpu_vinotify_event: tstamp:42888132076 tag:FE channel:0x01 frame:2 vi_tstamp:42888117158 data:0x00000022
kworker/0:3-20341 [000] … 1360.815640: rtcpu_vinotify_error: tstamp:42888211500 tag:CHANSEL_NOMATCH channel:0x44 frame:3 vi_tstamp:42888210834 data:0x000003c9
kworker/0:3-20341 [000] … 1360.815641: rtcpu_vinotify_event: tstamp:42888211775 tag:FS channel:0x01 frame:3 vi_tstamp:42888208417 data:0x00000012
kworker/0:3-20341 [000] … 1360.815643: rtcpu_vinotify_event: tstamp:42888211914 tag:CHANSEL_NOMATCH channel:0x44 frame:3 vi_tstamp:42888210834 data:0x000003c9
kworker/0:3-20341 [000] … 1360.815645: rtcpu_vinotify_event: tstamp:42889133859 tag:CHANSEL_PXL_EOF channel:0x23 frame:3 vi_tstamp:42889129547 data:0x04370002
kworker/0:3-20341 [000] … 1360.815646: rtcpu_vinotify_event: tstamp:42889133999 tag:ATOMP_FRAME_DONE channel:0x23 frame:3 vi_tstamp:42889129565 data:0x00000000
kworker/0:3-20341 [000] … 1360.815648: rtcpu_vinotify_event: tstamp:42889134160 tag:RESERVED_19 channel:0x23 frame:3 vi_tstamp:41012284800 data:0x02020001
kworker/0:3-20341 [000] … 1360.815649: rtcpu_vinotify_event: tstamp:42889134296 tag:CHANSEL_FAULT channel:0x23 frame:3 vi_tstamp:42889130466 data:0x04380040
kworker/0:3-20341 [000] … 1360.815651: rtcpu_vinotify_event: tstamp:42889134453 tag:RESERVED_19 channel:0x23 frame:3 vi_tstamp:41012314080 data:0x01020001
kworker/0:3-20341 [000] … 1360.815653: rtos_queue_send_from_isr_failed: tstamp:42889142623 queue:0x0bcb41f8
kworker/0:3-20341 [000] … 1360.815655: rtos_queue_send_from_isr_failed: tstamp:42889142784 queue:0x0bcb8a60
kworker/0:3-20341 [000] … 1360.815657: rtos_queue_send_from_isr_failed: tstamp:42889142936 queue:0x0bcba5e0
kworker/0:3-20341 [000] … 1360.815658: rtos_queue_send_from_isr_failed: tstamp:42889143085 queue:0x0bcbb3a0
kworker/0:3-20341 [000] … 1360.815660: rtos_queue_send_from_isr_failed: tstamp:42889143243 queue:0x0bcbc160
kworker/0:3-20341 [000] … 1360.871593: rtcpu_vinotify_event: tstamp:42889446923 tag:FE channel:0x00 frame:3 vi_tstamp:42889141713 data:0x00000022
kworker/0:3-20341 [000] … 1360.871597: rtcpu_vinotify_event: tstamp:42889447094 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:42889141714 data:0x00000000
kworker/0:3-20341 [000] … 1360.871599: rtcpu_vinotify_event: tstamp:42889447237 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:41012674912 data:0x07020002
kworker/0:3-20341 [000] … 1360.871601: rtcpu_vinotify_event: tstamp:42889447396 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:41012680608 data:0x10000000
kworker/0:3-20341 [000] … 1360.871602: rtcpu_vinotify_event: tstamp:42889447534 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:41012684512 data:0x31000003
kworker/0:3-20341 [000] … 1360.871604: rtcpu_vinotify_event: tstamp:42889447693 tag:FS channel:0x00 frame:4 vi_tstamp:42889233513 data:0x00000012
kworker/0:3-20341 [000] … 1360.871605: rtcpu_vinotify_event: tstamp:42889447835 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:42889233513 data:0x00000000
kworker/0:3-20341 [000] … 1360.871640: rtcpu_vinotify_event: tstamp:42889447992 tag:CHANSEL_PXL_SOF channel:0x23 frame:4 vi_tstamp:42889235949 data:0x00000001
kworker/0:3-20341 [000] … 1360.871641: rtcpu_vinotify_event: tstamp:42889448128 tag:RESERVED_19 channel:0x23 frame:4 vi_tstamp:41015689120 data:0x08020002
kworker/0:3-20341 [000] … 1360.871642: rtcpu_vinotify_event: tstamp:42889628707 tag:FE channel:0x01 frame:3 vi_tstamp:42889536917 data:0x00000022
kworker/0:3-20341 [000] … 1360.871644: rtcpu_vinotify_event: tstamp:42889628845 tag:FS channel:0x01 frame:4 vi_tstamp:42889628167 data:0x00000012
kworker/0:3-20341 [000] … 1360.871646: rtcpu_vinotify_error: tstamp:42889631246 tag:CHANSEL_NOMATCH channel:0x44 frame:4 vi_tstamp:42889630584 data:0x000003c9
kworker/0:3-20341 [000] … 1360.871648: rtcpu_vinotify_event: tstamp:42889916539 tag:CHANSEL_NOMATCH channel:0x44 frame:4 vi_tstamp:42889630584 data:0x000003c9
kworker/0:3-20341 [000] … 1360.871650: rtos_queue_send_from_isr_failed: tstamp:42890559843 queue:0x0bcb41f8
kworker/0:3-20341 [000] … 1360.871652: rtos_queue_send_from_isr_failed: tstamp:42890560000 queue:0x0bcb8a60
kworker/0:3-20341 [000] … 1360.871653: rtos_queue_send_from_isr_failed: tstamp:42890560153 queue:0x0bcba5e0
kworker/0:3-20341 [000] … 1360.871655: rtos_queue_send_from_isr_failed: tstamp:42890560301 queue:0x0bcbb3a0
kworker/0:3-20341 [000] … 1360.871656: rtos_queue_send_from_isr_failed: tstamp:42890560446 queue:0x0bcbc160
kworker/0:3-20341 [000] … 1360.871661: rtcpu_vinotify_event: tstamp:42890855649 tag:CHANSEL_PXL_EOF channel:0x23 frame:4 vi_tstamp:42890549308 data:0x04370002
kworker/0:3-20341 [000] … 1360.871662: rtcpu_vinotify_event: tstamp:42890855813 tag:ATOMP_FRAME_DONE channel:0x23 frame:4 vi_tstamp:42890549326 data:0x00000000
kworker/0:3-20341 [000] … 1360.871663: rtcpu_vinotify_event: tstamp:42890855953 tag:RESERVED_19 channel:0x23 frame:4 vi_tstamp:41057717152 data:0x02020002
kworker/0:3-20341 [000] … 1360.871665: rtcpu_vinotify_event: tstamp:42890856111 tag:CHANSEL_FAULT channel:0x23 frame:4 vi_tstamp:42890550228 data:0x04380040
kworker/0:3-20341 [000] … 1360.871666: rtcpu_vinotify_event: tstamp:42890856248 tag:RESERVED_19 channel:0x23 frame:4 vi_tstamp:41057746464 data:0x01020002
kworker/0:3-20341 [000] … 1360.871667: rtcpu_vinotify_event: tstamp:42890856411 tag:FE channel:0x00 frame:4 vi_tstamp:42890561472 data:0x00000022
kworker/0:3-20341 [000] … 1360.871669: rtcpu_vinotify_event: tstamp:42890856552 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:42890561473 data:0x00000000
kworker/0:3-20341 [000] … 1360.871670: rtcpu_vinotify_event: tstamp:42890856712 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:41058107200 data:0x07020003
kworker/0:3-20341 [000] … 1360.871671: rtcpu_vinotify_event: tstamp:42890856847 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:41058113440 data:0x10000000
kworker/0:3-20341 [000] … 1360.871673: rtcpu_vinotify_event: tstamp:42890857006 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:41058117344 data:0x31000004
kworker/0:3-20341 [000] … 1360.871674: rtcpu_vinotify_event: tstamp:42890857142 tag:FS channel:0x00 frame:1 vi_tstamp:42890653263 data:0x00000012
kworker/0:3-20341 [000] … 1360.871675: rtcpu_vinotify_event: tstamp:42890857303 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:42890653263 data:0x00000000
kworker/0:3-20341 [000] … 1360.871677: rtcpu_vinotify_event: tstamp:42890857438 tag:CHANSEL_PXL_SOF channel:0x23 frame:1 vi_tstamp:42890655699 data:0x00000001
kworker/0:3-20341 [000] … 1360.871678: rtcpu_vinotify_event: tstamp:42890857595 tag:RESERVED_19 channel:0x23 frame:1 vi_tstamp:41061121120 data:0x08020003
kworker/0:3-20341 [000] … 1360.871679: rtcpu_vinotify_event: tstamp:42890957220 tag:FE channel:0x01 frame:4 vi_tstamp:42890956678 data:0x00000022
kworker/0:3-20341 [000] … 1360.871681: rtcpu_vinotify_error: tstamp:42891051005 tag:CHANSEL_NOMATCH channel:0x44 frame:1 vi_tstamp:42891050335 data:0x000003c9
kworker/0:3-20341 [000] … 1360.871683: rtos_queue_peek_from_isr_failed: tstamp:42891121070 queue:0x0bcbcf78
kworker/0:3-20341 [000] … 1360.927589: rtcpu_vinotify_event: tstamp:42891262539 tag:FS channel:0x01 frame:1 vi_tstamp:42891047917 data:0x00000012
kworker/0:3-20341 [000] … 1360.927593: rtcpu_vinotify_event: tstamp:42891262679 tag:CHANSEL_NOMATCH channel:0x44 frame:1 vi_tstamp:42891050335 data:0x000003c9
kworker/0:3-20341 [000] … 1360.927595: rtos_queue_send_from_isr_failed: tstamp:42891980427 queue:0x0bcb41f8
kworker/0:3-20341 [000] … 1360.927597: rtos_queue_send_from_isr_failed: tstamp:42891980581 queue:0x0bcb8a60
kworker/0:3-20341 [000] … 1360.927598: rtos_queue_send_from_isr_failed: tstamp:42891980734 queue:0x0bcba5e0
kworker/0:3-20341 [000] … 1360.927599: rtos_queue_send_from_isr_failed: tstamp:42891980882 queue:0x0bcbb3a0
kworker/0:3-20341 [000] … 1360.927601: rtos_queue_send_from_isr_failed: tstamp:42891981027 queue:0x0bcbc160
kworker/0:3-20341 [000] … 1360.927602: rtcpu_vinotify_event: tstamp:42892076318 tag:CHANSEL_PXL_EOF channel:0x23 frame:1 vi_tstamp:42891969068 data:0x04370002
kworker/0:3-20341 [000] … 1360.927604: rtcpu_vinotify_event: tstamp:42892076460 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:42891969085 data:0x00000000
BRs
thanks
