Video input freeze when opening more than 2 cameras at the same time
Hi forum,
I tried to modified camera driver to enable xavier to support 6 cameras using ti 954, ti953 and imx390.
And I can open one camera, from /dev/video0-5, but when I use gstreamer command to open more than 2 cams, it failed.
gst-launch-1.0 \
nvarguscamerasrc sensor-id=0 bufapi-version='TRUE' ! tee name=c0 \
nvarguscamerasrc sensor-id=1 bufapi-version='TRUE' ! tee name=c1 \
c0. ! 'video/x-raw(memory:NVMM), framerate=30/1, format=(string)NV12' ! nvvidconv ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=30/1, format=(string)NV12' ! queue ! m.sink_0 \
c1. ! 'video/x-raw(memory:NVMM), framerate=30/1, format=(string)NV12' ! nvvidconv ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=30/1, format=(string)NV12' ! queue !m.sink_1 \
nvstreammux name=m batch-size=2 width=1920 height=1080 live-source=1 batched-push-timeout=40000 ! queue ! nvmultistreamtiler width=1920 height=540 rows=1 columns=2 ! nvvideoconvert ! nvdsosd ! queue ! tee name=deep \
deep. ! nvegltransform ! nveglglessink sync='FALSE' -e
Any solution for this?
I am using jetson agx xavier and modifying kernel based on jetpack 4.4(l4t 32.4.3)
BR
Could you check if launch by v4l2-ctl and have more simple pipeline to clarify the issue.
v4l2-ctl --stream-user --set-ctrl bypass_mode=0 --stream-count=100 -d /dev/video0 &&
v4l2-ctl --stream-user --set-ctrl bypass_mode=0 --stream-count=100 -d /dev/video1
Hi Shane.
Because the command you gave returned Invalid Atgument. So I tried
v4l2-ctl --set-fmt-video=width=1920,height=1100,pixelformat=RG12 --set-ctrl bypass_mode=0 --stream-mmap -d /dev/video0 && v4l2-ctl --set-fmt-video=width=1920,height=1100,pixelformat=RG12 --set-ctrl bypass_mode=0 --stream-mmap -d /dev/video1 && v4l2-ctl --set-fmt-video=width=1920,height=1100,pixelformat=RG12 --set-ctrl bypass_mode=0 --stream-mmap -d /dev/video2
And it can work
Right should using --stream-mmap instead --stream-user. and please using & instead of && for launch two sensor at the same time.
Also if v4l2-ctl working well by the && Please try to use xvimagesink like below.
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920,height=1100,framerate=60/1,format=NV12' ! nvvidconv ! fpsdisplaysink video-sink=xvimagesink sync=false \
& gst-launch-1.0 nvarguscamerasrc sensor-id=1 ! 'video/x-raw(memory:NVMM),width=1920,height=1100,framerate=60/1,format=NV12' ! nvvidconv ! fpsdisplaysink video-sink=xvimagesink sync=false
Hi Shane. Thanks for the reply.
Actually using this command will make one or more camera freeze. But using v4l2-ctl will not
And also I got these error from nvargus
(NvCamV4l2) Error IoctlFailed:  (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function setControlValMultiple(), line 792)
(NvOdmDevice) Error IoctlFailed:  (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function setDeviceControls(), line 1856)
Looks like argus set some CID failed cause the error. Could you try to disable the CID add the flags to the sensor driver to try.
https://www.kernel.org/doc/html/v4.9/media/uapi/v4l/control.html
Hi Shane. Would you mind elaborating how to do this?
And there is a update, I tested v4l2-ctl several times, I will get this error even if I opened one /dev/video node
root@zlh-desktop:/home/astri/driver_testing_script# cat /sys/kernel/debug/tracing/trace | grep ERR
kworker/0:1-818   [000] ....   213.618909: rtcpu_nvcsi_intr: tstamp:7000713521 class:CORRECTABLE_ERR type:PHY_INTR phy:3 cil:0 st:0 vc:0 status:0x00000088
kworker/0:1-818   [000] ....   213.618909: rtcpu_nvcsi_intr: tstamp:7000713521 class:CORRECTABLE_ERR type:PHY_INTR phy:3 cil:1 st:0 vc:0 status:0x00000088
root@zlh-desktop:/home/astri/driver_testing_script# cat /sys/kernel/debug/tracing/trace | grep rtcpu_nvcsi_intr
kworker/0:1-818   [000] ....   213.618907: rtcpu_nvcsi_intr: tstamp:7000676371 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x00000001
kworker/0:1-818   [000] ....   213.618908: rtcpu_nvcsi_intr: tstamp:7000713521 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x00000088
 kworker/0:1-818   [000] ....   213.618908: rtcpu_nvcsi_intr: tstamp:7000713521 class:GLOBAL type:PHY_INTR0 phy:3 cil:1 st:0 vc:0 status:0x00000088
but I tested opening 1-5 devnode, they can run normally, unlike libargus. And there is a post about this error, the answer is to modify serdes_pixel_clk_hz, which I already set to 833333333.
How about try to boost the NVCSI/VI/ISP clocks to check it.
https://elinux.org/Jetson_TX2_Camera_BringUp
Hi, I’ve boosted the clock, but got the same result
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
The error tell the data lane control error for debug if not show every capture and can capture successful that could be ignore I think.
OK. Sometime I will get this error
NvCaptureStatusErrorDecode Stream 2.0 failed: sof_ts 0 eof_ts 6035105617568 frame 0 error 2 data 0x000000a2
NvCaptureStatusErrorDecode Capture-Error: CSIMUX_FRAME (0x00000002)
A FS packet was found for a virtual channel that was already in frame.An errored FE packet was injected before FS was allowed through.
To get full binary VC number, user need to concatenate VC[3:2] and VC[1:0] together.
And also, normally there will be, no reply from camera processor, in dmesg
I solved this problem.
It’s because camera initialization time out. I set the enableCamInfiniteTimeout=1 or set the set_mode_delay_ms larger, it can work
Hi Shane,
although I can open up to 8 cameras using fpdlink serdes, but camera input will freeze and the error is
CsimuxFrameError_Regular : 0x000000a0
Stream ID                [ 2: 0]: 0
VPR state from fuse block    [ 3]: 0
Frame end (FE)              [ 5]: 1
    A frame end has been found on a regular mode stream.
FS_FAULT                    [ 7]: 1
Binary VC number [3:2]   [27:26]: 0
SCF: Error InvalidState: Capture error with status 2 (channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 880)
NvCaptureStatusErrorDecode Stream 0.1 failed: sof_ts 855127029120 eof_ts 855148679840 frame 37 error 2 data 0x000000a0
FS_FAULT                    [ 7]: 1
NvCaptureStatusErrorDecode Stream 0.1 failed: sof_ts 0 eof_ts 855164282464 frame 0 error 2 data 0x000000a0
FS_FAULT                    [ 7]: 1
NvCaptureStatusErrorDecode Stream 0.1 failed: sof_ts 0 eof_ts 859288546112 frame 0 error 2 data 0x000000a0
FS_FAULT                    [ 7]: 1
NvCaptureStatusErrorDecode Stream 0.1 failed: sof_ts 0 eof_ts 859288814240 frame 0 error 2 data 0x000000a0
FS_FAULT                    [ 7]: 1
NvCaptureStatusErrorDecode Stream 0.1 failed: sof_ts 0 eof_ts 859293412960 frame 0 error 2 data 0x000000a0
FS_FAULT                    [ 7]: 1
NvCaptureStatusErrorDecode Stream 0.1 failed: sof_ts 0 eof_ts 859296879712 frame 0 error 2 data 0x000000a0
FS_FAULT                    [ 7]: 1
NvCaptureStatusErrorDecode Stream 0.1 failed: sof_ts 0 eof_ts 859297762912 frame 0 error 2 data 0x000000a0
FS_FAULT                    [ 7]: 1
NvCaptureStatusErrorDecode Stream 0.0 failed: sof_ts 859286940256 eof_ts 27497774275584 frame 42 error 14 data 0x00020000
NvCaptureStatusErrorDecode Capture-Error: FALCON_ERROR (0x0000000e)
SCF: Error InvalidState: Capture error with status 14 (channel 0) (in src/services/capture/NvCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 880)
NvCaptureStatusErrorDecode Stream 0.0 failed: sof_ts 0 eof_ts 859305443584 frame 0 error 2 data 0x000000a0
FS_FAULT                    [ 7]: 1
SCF: Error InvalidState:  (propagating from src/services/gl/EGLStreamProducer.cpp, function presentBufferInternal(), line 539)
=== gst-launch-1.0[9411]: Connection closed (7F8339D1D0)=== gst-launch-1.0[9411]: WARNING: CameraProvider was not destroyed before client connection terminated.=== gst-launch-1.0[9411]:          The client may have abnormally terminated. Destroying CameraProvider...=== gst-launch-1.0[9411]: CameraProvider destroyed (0x7f7c810080)=== gst-launch-1.0[9411]: WARNING: Cleaning up 5 outstanding requests...=== gst-launch-1.0[9411]: WARNING: Cleaning up 5 outstanding streams...SCF: Error InvalidState: 6 buffers still pending during EGLStreamProducer destruction (propagating from src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 306)
SCF: Error InvalidState:  (propagating from src/services/gl/EGLStreamProducer.cpp, function ~EGLStreamProducer(), line 50)
SCF: Error InvalidState: 4 buffers still pending during EGLStreamProducer destruction (propagating from src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 306)
SCF: Error InvalidState: 5 buffers still pending during EGLStreamProducer destruction (propagating from src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 306)
=== gst-launch-1.0[9411]: WARNING: Cleaning up 5 outstanding stream settings...
=== gst-launch-1.0[9411]: WARNING: Cleaning up 5 outstanding sessions...Segmentation fault (core dumped)
The ending part is I use control-c to close the gstreamer pipeline and nvargus-daemon just return segmentation fault. And if I boost the clock, gst command can not open camera and nvargus-daemon will freeze directly
The error tell NVCSI/VI got FS package in the frame middle.
Could you try single or less cameras to clarify the problem.
Hi Shane,
this issue happened when I used even 1 camera
It could be the signal cause the problem.
Could you check if can get the data by v4l2-ctl continuously.
v4l2-ctl --set-ctrl bypass_mode=0 --stream-mmap
just as I described here, running 5 v4l-ctl command in 5 separate terminals can work, although sometimes one device will freeze and reset
but I set the camera can only stream 30 fps in dts, don’t know why it always stream 53 fps
Always the same device freeze or dynamic happened?
Hi Shane,
I remember in most cases, cam connected to csi-g tends to freeze first.
But I ran bist of fpdlink, the connection of serdes should be fine
Could you make sure of it.
And what do you mean “But I ran bist of fpdlink, the connection of serdes should be fine”
