Dear Jerry,
here another error log please can you look at it?
root@tegra-ubuntu:/home/nvidia# /usr/sbin/nvcamera-daemon
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/h3tx2_centerleft_P5V27C.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/h3tx2_centerleft_P5V27C.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/h3tx2_centerleft_P5V27C.isp] 8/16---- imager: No override file found. ----
LSC: LSC surface is not based on full res!
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/h3tx2_topleft_P5V27C.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/h3tx2_topleft_P5V27C.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/h3tx2_topleft_P5V27C.isp] 8/16---- imager: No override file found. ----
LoadOverridesFile: looking for override file [/Calib/camera_override.isp] 1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp] 2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp] 3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp] 4/16LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp] 5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/h3tx2_bottomleft_P5V27C.isp] 6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/h3tx2_bottomleft_P5V27C.isp] 7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/h3tx2_bottomleft_P5V27C.isp] 8/16---- imager: No override file found. ----
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 2147483647 Set = 2250000 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 4294967294 Set = 2250000 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 6442450941 Set = 2250000 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
PowerServiceCore:handleRequests: timePassed = 904
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 2148783647 Set = 2250000 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
NvViErrorDecode Stream 2.0 failed: ts 729200856416 frame 654 error 2 data 0x000000a2
NvViErrorDecode CaptureError: CsimuxFrameError (2)
NvViErrorDecode See https://wiki.nvidia.com/wmpwiki/index.php/Camera_Debugging/CaptureError_debugging for more information and links to documents.
CsimuxFrameError_Regular : 0x000000a2
Stream ID [ 2: 0]: 2
VPR state from fuse block [ 3]: 0
Frame end (FE) [ 5]: 1
A frame end has been found on a regular mode stream.
FS_FAULT [ 7]: 1
A FS packet was found for a virtual channel that was already in frame. An errored FE packet was injected before FS was allowed through.
captureErrorCallback Stream 2.0 capture 4128 failed: ts 729200856416 frame 654 error 2 data 0x000000a2
SCF: Error InvalidState: (propagating from src/services/capture/CaptureServiceDeviceViCsi.cpp, function startCapture(), line 708)
SCF: Error InvalidState: (propagating from src/services/capture/CaptureServiceCore.cpp, function doCSItoMemCapture(), line 418)
SCF: Error InvalidState: (propagating from src/services/capture/CaptureServiceCore.cpp, function issueCapture(), line 356)
SCF: Error InvalidState: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1213)
SCF: Error InvalidState: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueBubbleFillCapturesIfNeeded(), line 678)
SCF: Error InvalidState: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1054)
SCF: Error InvalidState: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
SCF: Error InvalidState: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 131)
SCF: Error InvalidState: Capture Scheduler not running (in src/services/capture/CaptureServiceDevice.cpp, function addNewItemToSchedule(), line 841)
SCF: Error InvalidState: (propagating from src/services/capture/CaptureService.cpp, function addRequest(), line 739)
SCF: Error InvalidState: (propagating from src/components/stages/SensorCaptureStage.cpp, function doHandleRequest(), line 87)
SCF: Error InvalidState: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 591)
SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 358)
SCF: Error InvalidState: (propagating from src/components/stages/MemoryToISPCaptureStage.cpp, function doHandleRequest(), line 129)
SCF: Error InvalidState: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 992)
SCF: Error Timeout: (propagating from src/components/amr/Snapshot.cpp, function waitForNewerSample(), line 92)
SCF_AutocontrolACSync failed to wait for an earlier frame to complete.
SCF: Error Timeout: (propagating from src/components/ac_stages/ACSynchronizeStage.cpp, function doHandleRequest(), line 126)
SCF: Error Timeout: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 137)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
Br.
